Vibration around the drive shaft or transmision
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joseriv20, Apr 28, 2021.
  1. Apr 28, 2021 at 12:54 PM
    joseriv20
    joseriv20 [OP] New Member
    Jose
    2008 Toyota Tacoma Prerunner
    None
    I changed the clutch assembly today because of some weird vibration when I started the first gear. As I drove away from the repair shop I feel there is more vibration and even on the reverse gear. What could this be.
  2. Apr 28, 2021 at 4:50 PM
    summithightacoma22
    summithightacoma22 Well-Known Member
    michael
    denver
    2013 grey tacoma trd sport
    front +2 allpro long travel with kings. Marlin crawler lca reinforcements, alpine design cab mount. All pro spindle and upper control arm reinforcements. Willwood 6 piston front calipers and 2 piece rotors. rear 7 pack expedition soa, 12 2.5s, archive garage shock relocation kit. Archive garage shackle flip kit. wheels 285/75/17 geolander g0003 on 17x9 with a zero offset. engine bay. antigravity atx hd-20 lithium battery arb high capacity air compressor. 3* exhaust cam timing. intake spacer custom stuff custom made sliders, custom bed rack system, custom drawer and bed system, modified mounts for arawak awning. Fiberglass/lexan cap door. Boxed out frame in spots I could reach. soon to be a chopped bed at the rear axle interior -lathewerks co polymer stainless shift knob, modified from a wrx to fit. -pioneer mid and treble speaker replacement. -future mods -4.56 gears arb front and rear lockers -traction bar for the rear. -full carbon front clip. -supercharger eventually.
    I get low rpm vibrations in 1rst and reverse. Seems to be the high torque required to get the vehicle moving causes the 2 piece drive shaft to vibrate at the carrier bearing as it wears out. I might suggest either a one piece rear drive shaft, or replacing the carrier bearing, which holds the middle joint on a 2 piece drive shaft.
  3. Apr 29, 2021 at 1:43 PM
    Eastkat808
    Eastkat808 Well-Known Member
    Esket
    2012 DCLB 4x4 sr5
    bilstein 5100 cranked up
    How’s your ujoints ?
    Jimmyh likes this.
