Vibration at 30-40 mph
Discussion in 'Technical Chat' started by Donnye13, Oct 31, 2022.
  1. Oct 31, 2022 at 8:17 PM
    Donnye13
    Donnye13 [OP] Active Member
    Donny
    2007 TRD Sport Tacoma
    I have a 2007 TRD sport with just south of 200,000 miles. Within the last couple thousand miles I’ve started to get a vibration in the truck when hitting 30-40 MPH. I’ve been basically ignoring the issue and hoping it goes away but it doesn’t seem like that’s the case here. It hasn’t effected gas mileage and I haven’t noticed any unusual leaks. (Right before the issue started I had a major repair to fix multiple oil leaks) I changed the spark plugs recently and I’m fairly confident it’s not an alignment or tire issue. Feels like some kind of a transition issue but I’m getting no lights on the dash or any transmission fluid leaks. Could this be a ECU issue? Any help would be greatly appreciated.
  2. Oct 31, 2022 at 8:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is your truck a manual or Automatic?
    If Automatic, does it do it if you leave it in 4th gear?
    You might also try driving in 4WD, see if it goes away in 4WD.
    Let us know if it goes away when testing the 2 suggestions above.
  3. Oct 31, 2022 at 8:26 PM
    Donnye13
    Donny
    Automatic, I’ll give those a shot thank you.
    TnShooter likes this.
  4. Nov 1, 2022 at 8:57 AM
    Donnye13
    Donny
    Looks like when driving in 4th the problem doesn’t occur. What could this mean?
  5. Nov 1, 2022 at 9:14 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Torque converter shudder probably. Next time it starts to shudder, lightly tap the brake with foot still on gas and see if it stops. TC unlocks when brake switch is on.
  6. Nov 1, 2022 at 9:17 AM
    Donnye13
    Donny
    Is this something that you’d recommend getting checked out sooner then later? I’ve been driving on it for some time and it hasn’t really effected anything. I’ve noticed when I’m driving and it starts to shudder if I take off the gas and then accelerate through I get no shudder.
    Sol6 and IvanhoeTaco like this.
  7. Nov 1, 2022 at 9:20 AM
    IvanhoeTaco
    Eastern NC
    It means the transmission fluid needs to be serviced. Wont leave you on the side of the road by any means but its something that should be done if your having symptoms like that.
  8. Nov 1, 2022 at 9:21 AM
    IvanhoeTaco
    Eastern NC
    And yes, a TC shudder is only felt light throttle partial load.
  9. Nov 1, 2022 at 9:21 AM
    Donnye13
    Donny
    Sounds good thank you for the insight I really appreciate it.
    IvanhoeTaco likes this.
  10. Nov 1, 2022 at 1:23 PM
    TnShooter
    Deogee
    STOCK
    About the only thing you can do “cheap” is drain and fill and add LubeGuard.
    Even better would be to drop the pan and clean the magnets and change the filter.
    Shudder is a known issue on some trucks.
    There’s multiple threads on the issue.
    If you really want to know all about the A750 Automatic Transmission, I’d start here.
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
    This is LubeGuard. - https://www.amazon.ca/Lubegard-6301...qid=1547097336&sr=8-2&keywords=lubegard+60902
    There are multiple people that have drained and refilled the transmission and added LubeGurad and it solved the shudder. But there are also people that have done the same, and the shudder was still there.
    I guess my pint is, LubeGuard is cheap compared to pulling the transmission and replacing the TC.
    It’s worth a shot.
  11. Apr 14, 2025 at 7:01 PM
    Sol6
    Sol6 New Member
    ‘09 Tacoma 4x4 V6 PreRunner
  12. Apr 14, 2025 at 7:03 PM
    Sol6
    Sol6 New Member
    I’m currently having the same issue. Did your issue with vibration at 30-40 mph get resolved? Are you able to drive it in automatic (not 4th gear) without it vibrating?
