Vibration at 40 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomariley09, Nov 26, 2022.
  1. Nov 26, 2022 at 9:09 AM
    tacomariley09
    tacomariley09 [OP] Member
    2013 White Tacoma 2WD Prerunner
    Leveling kit
    Hello, I have a 2013 Tacoma and I’m getting vibrations only at 40mph. I took it to the shop and couldn’t figure out why it’s shaking. My rear tires were worn on the outsides so I decided to start there and get new tires. I got new tires and still have the vibration. The wheels have been balanced and they did an alignment. Has anyone had this problem and found a solution? TIA
  2. Nov 26, 2022 at 11:07 AM
    Shawner1974
    Shawner1974 Well-Known Member
    Shawn
    CNY
    2012 Base Tacoma 2.7. 5 spd Regular Cab
    You didn't say how many miles on your rig, but I'm dealing with same issue. If it goes away when you switch to 4wd, it's probably the needle bearing on the driver's side of the front diff. I'm just gonna deal with it till spring...too cold to change it out now lol.
    disel_V1 and tacomariley09[OP] like this.
  3. Nov 26, 2022 at 11:45 AM
    tacomariley09
    Leveling kit
    Sorry, I just hit 100k miles. I will test that out and see! Thanks
  4. Nov 26, 2022 at 12:28 PM
    Shawner1974
    Shawn
    CNY
    Yeah just get up to speed (in a straightaway) and click it into 4wd. It will be undeniable if that's the problem. I see that ECGS makes a bushing to replace it. Do a search for 'ECGS bushing'. Lots of info on here about it.
    tacomariley09[OP] likes this.
  5. Nov 26, 2022 at 1:52 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    If it isnt the ECGS bearing issue, have you changed your ujoints? mine shook and then eventually started to squeak...
  6. Nov 26, 2022 at 2:04 PM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Auto or manual? Is the whole vehicle shaking or just front end?
  7. Nov 26, 2022 at 3:48 PM
    tacomariley09
    Leveling kit
    Auto. It seems to just be the front end and in the steering wheel
  8. Nov 26, 2022 at 3:49 PM
    tacomariley09
    Leveling kit
    No I haven’t changed my ujoints.
  9. Nov 26, 2022 at 4:07 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I had a similar issue and it was bad sway bar end links causing a shake.
  10. Nov 27, 2022 at 4:10 AM
    tacomariley09
    Leveling kit
    So I got it up to 40mph felt the vibration and switch it to 4wd and it went away
  11. Nov 27, 2022 at 4:48 AM
    MA_TACO
    Wesley Chapel, FL
    Sounds like a bad needle bearing
    MSgt O and tacomariley09[OP] like this.
  12. Nov 27, 2022 at 3:16 PM
    yeahdude97
    yeahdude97 Well-Known Member
    Mine has been doing this too, however the vibration doesn't seem to stop when its in 4x4. Most likely u joints?
  13. Nov 27, 2022 at 3:19 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Check carrier bearing also
    yeahdude97[QUOTED] likes this.
  14. Nov 27, 2022 at 4:39 PM
    tacomariley09
    Leveling kit
    So I don’t have a 4x4 and someone told me my truck doesn’t have the ECGS clamshell bushing but when I’m in drive and push it over to the 4th gear it goes away
  15. Nov 27, 2022 at 4:44 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    You are shifting it into S4 where you're limiting the top gear the transmission can go into. If it goes away when you do that then don't quote me but I think thats a sign of torque converter shudder. If the truck is 2WD then you do not have the front needle bearing
  16. Nov 28, 2022 at 6:18 AM
    MA_TACO
    Wesley Chapel, FL
    If thats the case then it's most likely torque converter shudder. I had the same issue and when shifted in 4th it would go away. I replaced the converter and the problem is gone.
  17. Nov 28, 2022 at 7:14 AM
    GA_Taco
    GA_Taco Active Member
    Canton GA
    2015 Tacoma TRD Sport
    I recently went through this same scenario. Front end was shaking. Getting vibration from the front between 30-40 mph. Everything went away as soon as you put it in 4wd.
    Needle bearing was bad. Replaced with ECGS bushing and all is back to normal
  18. Nov 28, 2022 at 8:39 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    my thought as well. I drive in 4th on the 40 mph roads
  19. Nov 29, 2022 at 1:36 AM
    MA_TACO
    Wesley Chapel, FL
    The problem with these toyota converters is the flex lockup. The clutch surfaces glaze over and shudders like crazy similar to a glazed flywheel surface in a manual transmission vehicle when you release the clutch pedal and vehicle shakes. There are some remedies like Lubegard Instant Shudder fix which does work but it's a temporary fix as the problem will eventually come back unless the converter is replaced.
    jeminyned and tacomariley09[OP] like this.
