vibration at 40mph
Discussion in '1st Gen. Tacomas (1995-2004)' started by chiefd, Nov 15, 2011.
  1. Nov 15, 2011 at 7:47 PM
    chiefd
    chiefd [OP] New Member
    arizona
    1999 Prerunner
    my 99 prerunner xcab vibrates between 40 and 45 mph and is smooth at all other speeds. I've repaced the struts, shocks, brakes and rotors--any suggestions?
  2. Nov 15, 2011 at 8:03 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    driveline maybe...
    I had a vibe at 40-45 and it was the u-joints. Go see if they have any play, also check your center support bearing to see if it has play. I did the two servicable rear u-joints and the center bearing and the vibes want away.
    Could even be a grease issue, when is the last time you greased the driveline?
  3. Nov 15, 2011 at 9:35 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    tires is my guess
  4. Nov 15, 2011 at 9:38 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    you've got 4 real options left.
    ~Road force balance tires.
    ~grease/replace u joints
    ~replace carrier bearing
    ~get a tom woods 1 piece shaft.
    I recommend going down the list, until it fixs the problem
  5. Nov 15, 2011 at 9:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Where do you feel the vibe? Steering wheel? Or floorboards/seats?
  6. Nov 16, 2011 at 6:34 PM
    chiefd
    arizona
    1999 Prerunner
    Thanks for the great advice, I'll start with the easy job, have the tires rebalanced and then takle the u-joints
