Vibration at 4200 rpm
Discussion in '1st Gen. Tacomas (1995-2004)' started by mcorbin, Jan 4, 2009.
  1. Jan 4, 2009 at 3:25 PM
    mcorbin
    mcorbin [OP] Member
    Taco Runner
    Texas Edition-wheels, flowmaster, k&n Filter, Nerf Bars
    Hello, I'm finally sending out my first post. I just bought a 2004 dbl cab with the 3.4l. The other day I finally put my foot in it and found that the truck has a strong vibration that you can feel in the floor after 4200 rpm and stops at about 4500. This is my first Taco, is this a normal characteristic? Thanks guys.
  2. Jan 6, 2009 at 7:16 AM
    mcorbin
    mcorbin [OP] Member
    Taco Runner
  3. Jan 6, 2009 at 7:25 AM
    mcorbin
    mcorbin [OP] Member
    Taco Runner
    only from 4200 to about 4500 rpm. the wierd thing is that the truck came with a flowmaster muffler. i switched to a borla muffler and the vibration lessened alittle. only the muffler has been changed on the truck, nothing else removed. this is really bothering me, please help.
  4. Jan 6, 2009 at 7:26 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    No this is not normal. It could be a number of things. I am suspecting a possible u-joint failure or out-of-ballance tire(s). If it is a tire, you should feel it in the steering wheel. To check the u-joint, grab the drive shaft and see if there is any side-to-side movement or rotational slop. Another characteristic of a bad u-joint is a clunking sound on take off and slow down. Hope this helps.
  5. Jan 6, 2009 at 7:34 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Highly likely. I would expect a rattling sound too. The fact that the OP can feel it in the floor board is trouble some though.
  6. Jan 6, 2009 at 7:51 AM
    mcorbin
    mcorbin [OP] Member
    Taco Runner
    I thought the whole thing was strange, the truck only has 27k. Drives smooth to 85 mph. only vibrates at 4200 to 4500.
  7. Jan 7, 2009 at 12:34 PM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '04 SR5 TRD DC
    Is it lifted? When the driveline angle changes, vibrations can develop at the u-joints.
  8. Jan 7, 2009 at 4:02 PM
    mcorbin
    mcorbin [OP] Member
    Taco Runner
    No, all stock except for wheels, which are stock size and offset. i checked the center bearing and it has normal play. im at a loss.
  9. Jan 8, 2009 at 4:51 PM
    swsteven
    swsteven Well-Known Member
    houston tx
    2001 tacoma trd
    3 inch lift bilsteins and aal 16 inch pro comp wheels, m/t tires
    you could check ur motor mounts to see if there torn or maybe out of balance tires or check underneath ur car to see if your exhaust piping rubber bushings are still in tact
  10. Jan 8, 2009 at 10:20 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    I've been wanting to ask, but feel sorta stupid...do many of you spend much time doing 4500 rpm? Just curious, seems way up there...guess I'm just getting old...
    I wouldn't know if there was a problem at that rpm with my truck, 'cause it'll probably never be there :yawn:
    With an auto, I think you'd have to be doing 90+...
  11. Jan 9, 2009 at 5:18 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No. 4200-4500 seems high to me but I dont have the experience with the 3.4L. Where is the redline for that engine? My 2.7L was 5500. I rarely put it in the 4000 range.
  12. Jan 9, 2009 at 7:03 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    how do you not enter the 4k range on your 2.7?? im always near 5.. lol
    But hey on the question above, check your headers!! I knw on my 2.7 the bracket broke that held the header. I used a hose clamp to fix the noise\vib
  13. Jan 9, 2009 at 7:15 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I am old and drove it with a light foot. I always shifted around 3500-3750. I would occassionally re-face the tires.....:burnrubber:
  14. Jan 9, 2009 at 7:17 AM
    PrezidentRedz
    Redz
    Owings, MD
    yeah I hear yeah, I guess mine is just heavy.. and the 4.56 gears make 1st and 2nd kinda short.
  15. Jan 15, 2009 at 4:32 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    '01 Limited DoubleCab 4x4
    3" SL, Nerf Bars, 33" BFGs, K&N, Deckplate, Royal Purple
    That's odd that you have a vibration at a certain RPM and not a certain speed. If it was at a specific speed, I would say your tires are out of balance or your U Joints were bad. Also, I never run my 3.4 above 4200 rpms for a constant time so I'm not sure how to help you here.
  16. Jan 16, 2009 at 10:42 AM
    mcorbin
    mcorbin [OP] Member
    Taco Runner
    sorry, some of you misunderstood, I dont drive AT 4200 rpm, when I accellerated to see what the truck could do, is when the truck vibrated.
  17. Jan 25, 2010 at 9:19 PM
    ywen
    ywen Well-Known Member
    the driveshaft is right underneath the driverside floorboard right? Wouldn't that cause you to feel something thru the floor?
  18. Jan 25, 2010 at 10:39 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    how are your exhaust hangers?
    im running a flowmaster 40 angled up a lil with the tailpipe cut before the axle and when the motor is cold and the truck idles high, i can feel and hear it in the cab...
  19. Jan 25, 2010 at 10:45 PM
    mcorbin
    mcorbin [OP] Member
    Taco Runner
    the vibration is isolated to the engine and/or t convertor. Exhaust is fine. vehicle vibrates at 4200 in nuetral, park and when driving. harmonic balancer isn't wobbling or any drive belt harmonics. I dunno.
  20. Jan 25, 2010 at 10:45 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    mine vibrates around 3100 rpms but I feel it in the stick shift and it goes away around 3300. but sounds semi similar. dont knwo what it is though
