Vibration at 60-70
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silverbullet85!, Jun 4, 2025.
  1. Jun 4, 2025 at 10:14 PM
    Silverbullet85!
    Silverbullet85! [OP] New Member
    Eddie
    2006 Tacoma 4x4 4.0
    3in lift
    Hello I have a 2006 Tacoma v6 4x4/and I’m having vibrations at60-70mph all the joints are including center bearing support are new I feel the vibration at 60-70 the floor vibrates but the steering wheel is good no shaking and rims are balance had a alignment done a few months ago
    Tires look good a lot of thread I don’t know what else to check can anyone help me with this I really appreciate
  2. Jun 5, 2025 at 11:59 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Try swapping the wheels front to back. Does the steering wheel then shake? If so it's one of the front wheels. If not then likely drive line like make a Ujoints. Is your truck lifted?
  3. Jun 5, 2025 at 1:33 PM
    Silverbullet85!
    Eddie
    2006 Tacoma 4x4 4.0
    3in lift
    It’s lifted 3inches the steering wheel doesn’t shake and the ujoint an are pretty new couple of months on them all 3 were replaced and I’ll try that switching the tires from front to back
  4. Jun 5, 2025 at 2:36 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Was the vibration there prior to the u-joint replacement?
  5. Jun 5, 2025 at 2:44 PM
    Barder07
    Barder07 New Member
    Anthony
    2015 TRD-Sport
    Are the u-joints out of phase with each other? If they aren't installed in phase they can cause lots of vibration.
  6. Jun 5, 2025 at 2:47 PM
    Silverbullet85!
    Eddie
    2006 Tacoma 4x4 4.0
    3in lift
    The vibration was there and that’s when I noticed the u joint wasn’t good so I replaced them all and then later came the center bearing support been 6months since the
    u joint was changed
  7. Jun 5, 2025 at 2:49 PM
    Silverbullet85!
    Eddie
    2006 Tacoma 4x4 4.0
    3in lift
    Out of phase sorry what does that mean ? That’s new to me
