Vibration at 60 MPH???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GeoTaco1, Jan 17, 2011.
  1. May 3, 2011 at 11:04 PM
    #101
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    My dad had the same problem and it was his u joints..
  2. May 4, 2011 at 12:51 AM
    #102
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Maybe it's your terrible roads.
  3. May 5, 2011 at 7:06 AM
    #103
    ShaneHD
    ShaneHD Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    I have been fighting this ever since they did the TSB leaf springs. Took it in a few weeks ago and the technician said "everything" was fine...(even though he didn't actually check the carrier bearing, u-joints, pinion or even wheel bearings like I wanted) and brushed it off to be road noise from the tires. He tried to show me a little wear on one of the tires. Thats BS because I rotate every 5k miles with them and I drive 99% highway, avoiding bumps and potholes.
    Mine happens at about 60mph as well, and goes away once I let off the gas. I am taking it back in and talking with the shop manager himself. I am thinking it is one (or more) things here:
    1. Pinion angle incorrect
    2. Bad u-joints
    3. Bad carrier bearing
    4. Incorrectly installed TSB leaf springs
    Anything else?
  4. May 5, 2011 at 4:23 PM
    #104
    Rayski196
    Rayski196 New Member
    Ray
    Zimmerman, MN
    05 SR5 Prerunner DC TRD Sport
    ShaneHD: Does your noise stop when you turn slightly to the left at speed?
  5. May 5, 2011 at 7:16 PM
    #105
    ShaneHD
    Fort Worth TX
    Not sure, but it goes away when I let off the gas. Frankly, I am thinking more and more that the pinion angle with the u-joints is off. When the gas is on, your pinion lifts up. If the angle is off, vibration WILL occur.
    Taking it to the dealership tomorrow for sure.
  6. May 6, 2011 at 5:28 AM
    #106
    antatich
    antatich Well-Known Member
    Tony
    Bremen, Indiana
    2011 DC Silver Tacoma
    Ready lift SST w/ 2 inch blocks, 33x12.50R17 Dick Cepek Mud Country Tires, 1.25" Billet Spacers, Tinted Windows, DDM tuning HID Headlights and Foglights, N-Fab Side Bars, N-Fab Light Bar, 4 Hella 500FF, JL Amp, 12" shallow Mount Sub
    3 degree axle shims is what someone else is recommending and my vibration doesn't go away when turning. Although its hard to feel now with the bigger mud tires on!
  7. May 10, 2011 at 8:34 AM
    #107
    Erll
    Erll Well-Known Member
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    I believe we the problem is the u joint angles.
    The thread is in my sig. It takes about 20 min and just a degree finder to check.
  8. May 10, 2011 at 8:57 PM
    #108
    ShaneHD
    Fort Worth TX
    Mine is at the dealership now. Dropped it off on my way home from work. Service Manager actually rode with me and heard the problem as well. They sent me home in a rental (not a loaner) Highlander, but are fitting the bill on it. All in all I believe the dealership I go to regularly will fix this issue. We shall see what they have to say.
  9. May 11, 2011 at 9:46 AM
    #109
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    good luck. they told me that it was "functioning as designed" notice they didn't say correctly, just "as designed"
  10. May 11, 2011 at 3:58 PM
    #110
    ShaneHD
    Fort Worth TX
    Master Technician ordered a new drive-shaft for me. Will be in and installed tomorrow. We will see if this goes away then.
  11. May 16, 2011 at 7:50 AM
    #111
    ShaneHD
    Fort Worth TX
    They changed the DS, took it for a test drive and the problem was still there. This has to be in the transmission, I am positive of it. They made asked me to bring it back in this morning. It's back with them now.
  12. May 16, 2011 at 10:10 AM
    #112
    GeoTaco1
    GeoTaco1 [OP] Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
    I thought is was trannie too. I am taking it in for the first service later on this week. I know they will say it is normal again!:mad:
  13. May 16, 2011 at 11:09 AM
    #113
    ShaneHD
    Fort Worth TX
    I spoke with my service rep a bit ago and they are trying the angle adjustments/shimming as suggest in another thread. I had sent that to them a few weeks ago.
    I ask him if this doesn't fix it, then what? He said "we may have to pass it off to Toyota and let them come up with a fix". This is unacceptable. I am to the point of where I hate to drive my truck. I feel like something is about to just break during the vibration.
    I am going to suggest again that they look at the transmission.
  14. May 17, 2011 at 10:23 AM
    #114
    GeoTaco1
    Geo
    But they don't know if it something that they can attempt to repair. They don't know if there is a true and consistent fix for this vibration.
    I asked them to document the findings above, I even brought all the pics from the thread above; they checked the angles, they said everything looks normal. If it gets worse, then it is documented and Toyota has to provide a general fix.
    Maybe they are waiting for a recall???:eek:
  15. May 20, 2011 at 8:05 PM
    #115
    ShaneHD
    Fort Worth TX
    All,
    Time to bring everyone up to speed on my dealership visits the last two weeks. Now, before I go into it, my dealership is GREAT and the people I have been working with are doing everything possible to accommodate this situation. They have offered me two different rentals, but here is here what they have done so far:
    1. First thing they did was order and replace the driveshaft. I am assuming this is new u-joints and carrier bearings as well, but I will need to verify. This did not resolve the issue
    2. They then tried the suggested shimming/angle changing of the driveshaft that was suggested in another thread. They had to buy the tool and order the shims, but were willing to try this if it had in fact worked for a user on here. This too did not resolve the issue.
    3. At this point, they wanted to point to the Bilstein 5100's that I had put on. I had set the front to 1.75", but this was only to level out the front from the rear due to the rear leaf spring TSB. I explained to them that there was no way it could be this because the noise was there before I put these on, it just wasn't that bad then. I and they suggested two things:
    A. I suggested setting my front 5100's to the lowest settings and put it back to stock height. This didn't work
    B. They suggested throwing on a new set of stock Bilstein's. I even told them that if this was the problem, I would gladly purchase the set from them, but I knew full well the shocks were not the problem. This didn't work either.
    After all of this had been tried, I was told they would be contacting Toyota directly for the next steps. Shortly after, I received a call from the service manager who said they had just ordered a brand new transmission and would be replacing this next week. This whole time I had been suggesting to them that I thought it was the trans, due to the fact that when I reached the "speeds" that the vibration would occur in OD, I would throw it down to 4th gear and the vibration went away. When they said they were replacing the whole trans, I asked if they had even opened it up to see what the issue might actually be. They just said it would be easier to replace the whole thing. Then he told me what Toyota was going to be paying them for all the work, and it was nearly as much as I bought the truck brand new for. Now, I don't know how this is so, but at which point does Toyota admit they have an issue on these trucks and do something more than just replace, replace and replace. When does lemon-law come into affect? Now again, I am blessed that this dealership is going the extra mile to get my issues taken care of, but I also feel horrible that it is costing so much money on Toyota's end.
    Now I am waiting on the new trans to come in. My question here I am wondering if the trans will actually be brand new or a refurbished. Anyone know how this all works?
    Does any of these make sense to the mechanics out there?
  16. May 20, 2011 at 8:06 PM
    #116
    ShaneHD
    Fort Worth TX
    I also took a large nail/screw on a tire this last weekend and have decided to purchase a new set of Firestone Destination AT's from this same dealer and will have them put on next week. It's the least I could do for all these guys have done for me.
  17. May 20, 2011 at 8:22 PM
    #117
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    ShaneHD.
    I have the exact same problem you do on my '11. It started when I had the TSB leafs put in also.
    I can't wait to hear what resolves it.
  18. May 20, 2011 at 8:51 PM
    #118
    ShaneHD
    Fort Worth TX
    I am almost to the point where if it is the leaf springs, REMOVE THEM and put stock springs back on.
  19. May 21, 2011 at 9:02 PM
    #119
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    Thankfully, mine isn't that bad. It's really doesn't become noticeable until after a 100 miles of highway driving when everything is nice and warm and loose.
    What scares me is I plan on putting 5100s on probably set at 1.75, so I'm afraid its only going to exagerate the problem.
    Really I'm just worried about the long term wear. Any vibration in the drive train is bound to cause premature wear on bearings and brushing. I don't want issues to creep up after the warranty is out.
  20. Jun 1, 2011 at 1:42 PM
    #120
    Erll
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    i just finished some other testing of drive line angles. I took out my 1.5 aal and added riderite air bags. the angles changed significantly ! (Airbags at 0psi) This would be the same as stock with the TSB.
    Vibes at sixty came back after removing the aal, so i followed the angles and started working from front to rear. Totally stock they were as follows
    t-case is my 0.0
    first shaft 2.8
    second shaft was 6.5
    and the diff was 2.9 from the second shaft
    solution for stock With TSB was a 3.0 degree axle shim and nothing more.
    no more 60 mph vibes.
    It seems as if (from reading here and my own testing ) that the 60mph vibe usually comes from the rear diff joint angle and the take off vibes are from the combination of the front and second joints. Can anyone else verify this?
