Vibration at 60 MPH???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GeoTaco1, Jan 17, 2011.
  1. Jul 21, 2011 at 10:12 PM
    #121
    Algtr
    Algtr Member
    2011 trd sport dc 4x4
    Any updates on the truck ? i too have the very exact same vibration you are expiriencing . :mad:
  2. Aug 5, 2011 at 1:04 PM
    #122
    ShaneHD
    ShaneHD Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    I can't believe I haven't updated this thread. Back in June, the issue was FINALLY resolved, but appears to be coming back. What finally fixed it was a whole new rear end (which again, I had advised from the beginning that the issue was a pinion bearing).
    All in all, here is what all Toyota had done:
    1. Replaced 2 piece driveshaft, carrier bearing and u-joints (didn't fix)
    2. Replaced full transmission (bought new tires from them too and still no fix)
    3. Pulled the rear end off of an updated truck (new), removed the 4 leaf spring system and put the new leaf springs and rear end on (PROBLEM SOLVED).
    However, it is starting to come back.
  3. Sep 15, 2011 at 7:23 PM
    #123
    matts11
    matts11 Well-Known Member
    TN
    Guys, I came across this thread by accident but thought I would chime in. Mine does the same thing but I never thought anything of it because my 04 4runner did the same thing at a slightly higher speed. I think it is the engine....it reminds me of an "exhaust moan" I had on an 02 Silverado that GM had a tsb about. Note that my 4runner had the same engine as the Tacomas but a different trans as it was the 4 speed auto. I think it is related to the engine resonating at certain rpms because as the OP mentioned it subsides when coasting or lightening up on the skinny pedal. I should mention it was widely discussed on t4r.org.....I think these engines just have a lot of NVH....and the torque converters send some vibes as well.
  4. Nov 9, 2011 at 5:44 AM
    #124
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Just to add to the thread - I have the same exact problem, and it's a new development. 2009 Sport DCab 4x4 auto w/ 75k miles. I have never had this before, but recently when going from about 60-72 there is the very noticable hum or groan from the truck. The best way I can describe it is that it "feels" like the truck is straining to accelerate (like it's going uphill without downshifting or accelerating into wind), but it's actually not. It is NOT tire related (I know what that feels like). There is no steering wheel vibration or anything of that nature, just feedback through the pedal. Doesn't matter if accelerating or not. I drive the truck 98% on the highway at 60+, so it's not like it's been abused. To add to what some others have said, it's recently gotten into the 30's here temeperature wise, and that's when I've noticed it starting.
    Bottom line I've gathered from reading this whole thread is that the consensus is that it's driveline related (I agree) but there is no 100% concrete fix. Unfortunately, I'm not in a position to throw a bunch of money into a problem that doesn't APPEAR to be doing any actual harm and goes away once I get into my most common driving speed. Just a frustating problem indeed.
  5. Nov 9, 2011 at 4:24 PM
    #125
    matts11
    TN
    I personally don't think it is driveline related. It makes no difference whether mine is in 4wd or 2wd, just whether or not I am either accelerating gently or going up an incline in top gear. Have you recently done anything related to the engine? As I mentioned, I had the same sensation at different speeds in my 4Runner which had the same engine, but different trans, tcase, etc.
  6. Nov 17, 2011 at 2:53 PM
    #126
    Snowman11
    Snowman11 Supreme Ruler
    Snow
    Near Philly
    2011 DCLB TuRD Sport
    5100 Billies
    Ok guys, I've been reading about these vibration issues for a year now. That's how long I've had my truck and that's how long I've had the vibration. Unfortunately I test drove a different truck cuz they didn't have the color so I ordered mine new.
    Anyway 60mph and over, it's been progressively worse. I have 14700 miles now and finally had time to take it in for my yearly inspection, oil change, new blower motor and the VIBRATION that actually shakes the passenger seat if nobody is in it. The dealer felt it and but couldn't find where it was coming from. They opened a Case # with Toyota and ended up doing what I suggested from all the reading: They rotated the carrier bearing housing 180 degrees where the drive shaft is held in place. They claim it's fixed but I won't get a chance to check their work until tomorrow morning. Wish me luck and I'll report back.
  7. Nov 18, 2011 at 4:44 AM
    #127
    rjbb2
    rjbb2 Member
    Bob
    NC
    2011 4x4
    Lighted 4x4 switch, Ipod direct adapter, Intermittent wiper, cruise control.
    I have this same problem since mile 2. I have had the tires balanced on rotated at least 4 times in 5000 miles. My passenger seat also shakes at 65-70 mph and it comes and goes. I am ready to yank the Dunlops off and put something else on, but I do not feel like throwing money at the problem if it is not going to fix it. It is driving me crazy so I will be curious to see if rotating the bearing housing will solve it?
  8. Nov 18, 2011 at 10:55 AM
    #128
    Snowman11
    Snow
    Near Philly
    5100 Billies
    Well I got to try it today. By the way I looked underneath to see if anything was done. I'm not a mechanic so bare with me as my story is changing slightly. The carrier bearing that is question is actually at the joint sort of in the middle of the drive shaft (2 piece drive shaft) to keep everything in line. It's hard to tell if they rotated the housing but I could definitely tell the whole bracket that holds the housing to the frame was slid to the drivers side by about 1/2 inch. Whether they did it on purpose or not I don't know but my guess is yes. What it did was to change the resonating frequency. In other words, it now vibrates more between 40-55 and much less between 60-75 but it still does it. I'd say the hum that hurts my ear is around 62.
    So-- I think since the housing is on slots, it is just two screws that you can loosen to move it around and change the angle enough where you may be able to find a happy medium?
    Sorry I dot have the end-all answer but maybe some help.
  9. Nov 18, 2011 at 8:05 PM
    #129
    Snowman11
    Snow
    Near Philly
    5100 Billies
    BTW I forgot to mention... the dealer said he never saw this before. I call B.S.
  10. Nov 19, 2011 at 6:34 AM
    #130
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    I had the same problems you guys are describing and finally got the dealer to agree to look into this further. Unfortunately I started to mod the truck so I know they won't be able to diagnose these issues further. I installed OME 885 coils up front with 90000 struts to handle weight of ARB and winch. I also put OME shocks in the rear (I have rear spring TSB too). Oddly enough the vibrations have gotten better.
  11. Nov 19, 2011 at 10:06 PM
    #131
    Algtr
    Algtr Member
    Can't seem to figure out whats the problem on mines also . while on the freeway i noticed it runs smooth till i hit 55mph , then i start to feel and hear a rum rum rum sound all the way up to 60mph, it drones out and go away after 60mph , im guessing it could be a torque converter related issue. my first oil change is due soon . I'll have them check it out and let you guys know the outcome!!!
  12. Nov 20, 2011 at 11:00 AM
    #132
    jgrm1
    jgrm1 Well-Known Member
    Midlothian / Waxahachie, Texas
    2021 Tacoma Double Cab Long Bed
    This did not fix my stock truck.
    -Jeff
  13. Nov 20, 2011 at 12:16 PM
    #133
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    Has anyone put washers on the carrier bearing to drop it slightly to see if it helps a stock truck?
  14. Nov 20, 2011 at 12:29 PM
    #134
    Snowman11
    Snow
    Near Philly
    5100 Billies
    I may be trying that, good idea
  15. Dec 2, 2011 at 6:16 PM
    #135
    Snowman11
    Snow
    Near Philly
    5100 Billies
    Well the vibration is getting REALLY bad after 60. Loud and almost undrivable. I called the dealer and said it's not fixed. He asked if I want an appointment. I said only if you give me a free loaner. He said only if he had it for more than 2 days. I said you had it for 2 days and said it was done. I said if I knew it wasn't finished, I would have made you keep it. He said he couldn't help. I told him nicely that I was going to call Toyota corporation and let them know what is going on. So I did. The Customer Relations Manager from the dealership called today and said that a corporate tech specialist comes once per month and got me an appointment for that day with a free loaner.
    See what happens when you don't take no...
    I hope to get to the bottom of this.
  16. Dec 3, 2011 at 5:25 AM
    #136
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    Did you ever try spacing the carrier bearing down? I might try it today because with the colder weather it seems to have gotten worse on my truck, the other thing I noticed is with a full tank almost no vibes but at 1/2 a tank it just keeps getting worse. Anybody else notice this?
  17. Dec 3, 2011 at 9:18 AM
    #137
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    I just added 3 3/8" fender washers with a slightly longer bolt to my carrier bearing, that got rid of 80% of my 69-74 MPH vibes. Glad I finally did it, give it a try it only cost me a few bucks and a trip to the hardware store, I sure hope it lasts.
  18. Dec 3, 2011 at 9:28 AM
    #138
    broken taco
    broken taco Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    mine starts vibrating a tiny bit when i hit 85. once i get up above 95 it goes away thoe
  19. Dec 13, 2011 at 3:40 PM
    #139
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Subbed to this for my expected battle with the dealer next week
  20. Dec 15, 2011 at 1:03 PM
    #140
    Snowman11
    Snow
    Near Philly
    5100 Billies
    Drop it off tomorrow to be 'fixed' can't wait!
