Vibration at 70mph after doing the following work...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bruno, Jul 2, 2012.
  1. Jul 2, 2012 at 10:18 AM
    Bruno
    Bruno [OP] Well-Known Member
    Bruno
    1996 4x4 V6 Xtra Cab 5spd
    1st Gen Fabtech Coilovers, Rear Add a Leaf, 33x12.5 BFG Mud Terrains, Deck Plate Mod
    I have a vibration that fades in and out constantly while driving at freeway speeds. Starts around 50mph and gets progressively louder. It comes from drivers side behind firewall. It started after replacing the steering bushings with the energy suspension ones.
    I'm 85% sure it's something between the tie rods and steering wheel (steering path).
    My question is what exactly would do this? Is my rack finally dying? The bushing install went mostly smooth, everything is tight and torqued. When a rack is dying, how can u tell?
    I have a 96 Tacoma 4x4 V6 with 1st gen fabtech coilovers and 33x12.5 BFG Mud Terrains. 182,000 miles. Lift/tires have been on for at least 80k. In the last 2 weeks I've done a grip of work including upper/lower moog ball joints, both cv axles, lube drive shafts, all fluids/filters and a handful of other stuff.
    Thanks for the help, appreciate it.
  2. Jul 3, 2012 at 4:58 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    i take it you put poly bushings in?
    If so it will enhance a vibe that the rubber one's will mask. Perhaps your inner tre's are showing age tires slightly out of round, ...
  3. Jul 3, 2012 at 4:59 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    bearings? :notsure:
  4. Jul 3, 2012 at 5:00 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Have you done inner and outer tie rods?
  5. Jul 3, 2012 at 5:02 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Maybe you threw a weight??? Whens the last time you rotated and balanced the tires???
  6. Jul 4, 2012 at 9:04 AM
    Bruno
    Bruno
    I've never done the inner and outer tie rods. And yeah, I put the poly ones in. Maybe I'll get some MOOGs.
    Haven't rotated and balanced in awhile, I'll do that before my cross country move. Never done bearings.
    The poly vs rubber makes a lot of sense to me, thought about that. As long as it all doesn't come apart, I'm ok with it.
    Any insight on the actual rack dying? I remember many years ago people saying that by putting bigger tires on, I'd have to replace my rack sooner...what am I looking for with this? Will it just fail and revert to non-power steering
  7. Jul 4, 2012 at 1:50 PM
    goomba
    Josh
    San Antonio Fl
    I have 290k on my original rack. 70k miles with 305/70s
