vibration at highway speeds but only in curves
Discussion in '2nd Gen. Tacomas (2005-2015)' started by island808, Sep 20, 2011.
  1. Sep 20, 2011 at 4:45 AM
    island808
    island808 [OP] Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Have a vibration that only shows up in curves. Can't quite tell where it's coming from. Could be front tires, almost seems like it's everywhere.
    Only have a few thousand miles and I have rotated my tires, probably "too much", no associated noises with vibration, brakes don't pulse. Have not checked hub temps (all my tools are on a boat, I have 2 screwdrivers and a digital caliper). Straight, no disernable vibrations, quite pronounced in curves on the highway at 60 or so and better.
    I've got a couple theories, but haven't found them to be true yet. It did just get shipped from hawaii to the east coast; so, anything could have happened in that voyage I guess.
    Anyone else have an idea of what would cause highway vibration but only in curves?
  2. Sep 20, 2011 at 6:47 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Have you had your alignment or balance checked? My 08 does this when I turn the wheel slightly off center at speeds above 45 mph & really shakes while going straight at those speeds. I've been fighting this since new. I put new Michelins on 3 months ago, still same problem. Last week Toyota engineer & service manager had my truck all day. They road force balanced 3 times, still shakes. Then they put factory tires w/same rims as mine on from a brand new 2011 & truck was smooth as glass. They say it's either my tires, rims or both causing the vibration.
  3. Sep 20, 2011 at 9:34 AM
    island808
    Jedediah
    hawaii
    I think I may do 1 or both of 2 things. I have a tiny spacer on there just for looks.
    I think I'll cross rotate the tires (as opposed to front to back only?) or maybe rotate the spare around the truck and see if I get any difference.
    If not, then I'll move to take off the spacers and see. Without my tools, it will take a LOT longer than usual to do this. So I've been putting it off. I haven't taken a tire off with a tire iron in years.
  4. Sep 20, 2011 at 9:46 AM
    charles08tacoma
    Santa Cruz, CA
    The crappy thing about my shaking is I put my spare on my left front & the vibration & shaking is almost gone. I'm going to cross rotate my fronts just for the heck of it even though RFB has been done 4 times in recent weeks. You never know what may work..... Mine is all stock w/no spacers.
  5. Sep 20, 2011 at 3:08 PM
    island808
    Jedediah
    hawaii
    Tijuana / american workmanship at it's best?
    There's a reason they sit where they do on the jd power. But it's almost all fixable. This is a problem that haunts many vehicles over history, but the first time I've had a strange one.
  6. Sep 20, 2011 at 3:21 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You're back
  7. Sep 21, 2011 at 2:52 AM
    island808
    Jedediah
    hawaii
    eh, don't get excited. Forums bring out the worst in me/others. I try to limit exposure now-a-days.
    Rotated one side last night (life without tools is hard) figured I'd stop there and see what happens.
  8. Sep 21, 2011 at 3:15 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    i found when i cross the back tires to the front they wear better and less vibes... seems to help with mine
  9. Sep 21, 2011 at 3:25 AM
    LEEP
    LEEP Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    maybe road surface uneven
  10. Sep 23, 2011 at 2:22 PM
    island808
    Jedediah
    hawaii
    I only rotated one side to help. Changed vibration... maybe? I'd say it's road but it happens a couple places on different highways. I'll track it down. Once my tools get here.. 29 sep.
  11. Sep 23, 2011 at 2:23 PM
    island808
    Jedediah
    hawaii
  12. Sep 23, 2011 at 2:26 PM
    island808
    Jedediah
    hawaii
    I rotated one side. Seems to have changed the vibration. Maybe? It's hard to tell, it's not severe. It MAY be the road surface, but it happens on multiple highways but only at certain spots, which I do at the same speed every day.
    I'll sort it when I get my tools.. 29 sep.
