Vibration at highway speeds that disapears after a few hard brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maadanchik, Feb 18, 2021.
  1. Feb 18, 2021 at 4:01 PM
    Maadanchik
    Maadanchik [OP] Member
    2017 TRD SPORT
    Hi all,
    I have a 2017 Tacoma TRD Sport with 6ft bed.
    Truck sat in a driveway for about 3 weeks and now when driving at highway speeds it has a vibration at the steering wheel that goes away after i brake hard a few times. Also the vibration changes when i drive at 4H, now it feels like the whole truck is shacking but the same thing happens, it goes away after a few hard brakes.
    I replaced my rotors and brake pads about 4 month ago so maybe the rotors are warped cant think about anything else but at the same time there is no vibration at the brake pedal when i brake.
    Does anybody had or have similar problem ?
  2. Feb 18, 2021 at 4:25 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Is it cold where you live? Tires get out of round a bit when sitting in cold.
    tonered and Skydvrr like this.
  3. Feb 18, 2021 at 4:33 PM
    Maadanchik
    2017 TRD SPORT
    Im from NY, today it was 31F.
  4. Feb 18, 2021 at 4:37 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Drive it a few times in a row after a few days. Report back.
  5. Feb 18, 2021 at 4:43 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    My '06 TRD OR AC, when driven at highway speeds after sitting overnight, always experienced a bit of vibration from 'flat' spots on the tires. Always went away after a few highway miles warmed up the tires.
    Maadanchik[OP] and hiPSI like this.
  6. Feb 18, 2021 at 4:49 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I have no idea why it would go away after braking, but my first thought when I have vibration at hiway speeds (in the steering wheel and/or stick shift) is out-of-balance wheels. It possible that some ice formed in your wheels while it was parked? Is there a possibility that mud got into the wheels prior to parking it? You should be able to inspect wheels and rule this in or out easily. If there is any in there, take it to a manual car wash and pressure wash the wheels. I go through this process on a regular basis, but it's because I take mine off-road a lot.
  7. Feb 18, 2021 at 6:10 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Start small. check the lug nuts. Some may have been loose or improperly torqued.
    Chew and Maadanchik[OP] like this.
  8. Feb 18, 2021 at 6:21 PM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    was the truck hot when you parked it initially, and you parked it with the wheels turned? That could possibly have warped the rotors.
  9. Feb 18, 2021 at 6:23 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
  10. Feb 19, 2021 at 12:55 PM
    Maadanchik
    2017 TRD SPORT
    We have snow here in NY, and thats what i thought but nope no mud or ice or snow build ups.
    Also the truck was parked outside, overnight for 12 hours in 29°F, drove it home and no vibration...it comes and goes like a ghost:( but def comes after the truck is parked for a day or 2...i am going to check the lug nuts although i did torque it to specs after replacing the rotors. Also if it keeps happening im going to rotate the wheels and do wheel alignment. Will update......
  11. Feb 19, 2021 at 1:00 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'd go with what @hiPSI said. The longer a vehicle sits, the more pronounced tire flat spots can be. Cold temps, certain tires, and lower pressures will make them worse. They go away when the tires warm up and flex. The time that you are parked at work is not long enough for them to develop.
    To test, add a few PSI to each tire from where you are at now. This will not affect anything much at all, but if the issue decreases, then flat spotting is the issue.
    Interestingly, the tires that I have now would flat spot in the cold when they were new. I've been expecting it to come back this winter, but nothing.
    Maadanchik[QUOTED][OP] and hiPSI like this.
  12. Feb 19, 2021 at 1:02 PM
    BCTSR5
    BCTSR5 NorthernTacoShop.com
    Vancouver
    2020 Taco TRD Sport
    rotor rust!
  13. Feb 19, 2021 at 1:13 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    I had 2 diff end vehicles that did same thing
    Both times had front tires rebalanced and it went away maybe you lost a tire wieght
    Could be flat spots like others have said because of cold
    tonered likes this.
  14. Feb 20, 2021 at 6:18 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    I agree probably rust on the rotor. That's why it stops after braking a few times.
    Maadanchik[OP] likes this.
  15. Feb 20, 2021 at 6:53 AM
    Maadanchik
    2017 TRD SPORT
    Update
    Checked the lugs, everything is tight.
    Second day driving no vibration
    I guess its either a flat spot on the tire or rust build up on the rotors.
    Thank you for the responses
    Chew likes this.
