vibration at idle
Discussion in '4 Cylinder' started by grumman41, Oct 1, 2009.
  1. Oct 1, 2009 at 7:49 AM
    grumman41
    grumman41 [OP] New Member
    central
    sr5
    I'v owned my 2003 2wd tacoma for about six months. It has about 63,000 miles and runs great(good power) but has a very rough idle, it even shakes my front grill and causes a resonance up front. sounds bad and is annoying.
    There is no maint lights lit and I have had it on the dealers computer, they said to run some chevron techron thru the system(I did).
    Where should I go from here?
    Thanks in advance! Kevin
  2. Oct 1, 2009 at 7:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Start with the plugs. They should be replaced every 30K miles. So they could be due....OR...if they are the original ones, that could be the problem.
  3. Oct 1, 2009 at 8:04 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2^^
    While you're at it you might consider just doing a tune up. Plugs, wires, distributer, air filter. Some folks on here are fans of using Seafoam as engine/fuel treatment.
  4. Oct 1, 2009 at 8:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No distributer on his truck. ;)
  5. Oct 1, 2009 at 1:24 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    gosh chris you just know friggin everything. you always amaze me.
  6. Oct 1, 2009 at 3:14 PM
    afd23a
    The Dynamo of Dixie
    :anonymous: thanks, wasn't sure about that one!
  7. Oct 1, 2009 at 3:36 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    i had a 99 2.7l it had a rough idle.even after a tuneup it was still there.i myself just got used to it.but if it bothers you that much give it a try,but you may chase this for awhile.
  8. Oct 1, 2009 at 3:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek:
    Your welcome. :)
