Vibration at speeds of 60-70 MPH
Discussion in 'New Members' started by Chief1959, Jul 7, 2012.
  1. Jul 7, 2012 at 8:46 AM
    Chief1959
    Chief1959 [OP] Well-Known Member
    James
    Springfield, Louisiana
    2023 Tacoma SR5
    Just purchased a base 2007 Tacoma (4Cyl). Great truck. The only thing I haven't been able to figure out is, at speeds of 60-70, really at 65 mph, there is (not a shake) but like a low pitch hum that does kind of reverberate through the whole truck. Initially I am thinking driveshaft out of balance or bad u-joints. Anyone have a suggestion? Or had the same problem?
  2. Jul 7, 2012 at 10:16 AM
    BrianLV
    BrianLV Well-Known Member
    Las Vegas
    04 Prerunner SR5
    I get similar vibrations on my 04. I just started greasing all my zirks, but maybe theres some play in the U joints, or carrier bearing. I actually wish I could go with a one piece drive shaft.
  3. Jul 28, 2012 at 10:54 AM
    Chief1959
    James
    2023 Tacoma SR5
    I finally brought my 07 Tacoma to a place that troubleshot down to the front wheel hub assemblies. This would make a vibration from 55-70, strongest at 65, as if you were sitting in a vibrating chair. I get the truck back Monday, I will let you know if it fixed the problem.
  4. Dec 20, 2012 at 8:29 PM
    1frkdog
    1frkdog Member
    1frkdog
    El Dorado Hills Ca
    98 Tacoma SR5 3.4 w/5spd
    KYB Shocks
    So were the hub assemblies the cause of the vibration??????????
  5. Jul 11, 2013 at 10:11 AM
    Chief1959
    James
    2023 Tacoma SR5
    Sorry, it's been awhile. No, it was the driveshaft.
