Vibration during braking????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Frank, Jul 9, 2010.
  1. Jul 9, 2010 at 3:09 PM
    Frank
    Frank [OP] Member
    Central Coast California
    02 PreRunner Double Cab Auto 2wd
    Shell, hood supports,dvd/gps/back up camera
    Hello, I'm having a problem with my Tacoma's brakes or something?
    History.
    I got vibration on braking. I changed my pads and rotors with something I got from a parts house. Within a year same problem (probable within 6 months).
    I went to Toyota and got genuine Tacoma parts. Within say 9 months same problem.
    This time I took it to a machanic. He replace the rotors and disks, this time the problem didn't go away. Still vibrating on braking.
    I went to Toyota and the service manager said to get on a safe hiway with no traffic and pull the parking brake to see if the vibration was there. It was.
    I took it in and had the rear drums replaced. Still same problem. Any Ideas?
    Frank
  2. Jul 9, 2010 at 3:10 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    Maybe your wheels need to be balanced? not sure sorry :/
  3. Jul 9, 2010 at 3:21 PM
    huntinggunns
    huntinggunns Lifes a garden, dig it.
    Fred
    Oklahoma
    2014 MGM SR5 DC SB TSS 4x4
    In progress
    Frank,
    I was an ASE certified brake specialist for many years. The only way you can get a vibration when braking is from a warped drum/rotor. Brakes work off of friction. Friction causes heat. Heat causes metal to warp. If you feel the vibration in the steering wheel it is usually from a warped rotor. If you feel it in your seat it is usually from a warped drum. Just because you replaced the drums does not mean they were machined right from the start or that it has not been dropped during shipping. Take the drums to a local shop and have them mount them on a brake lathe to check for runout and/or bent center where they mate to the axle.
    Fred
    razhick4x4 likes this.
  4. Jul 9, 2010 at 3:22 PM
    Frank
    Frank [OP] Member
    I haven't thought of that, but from my experiance out of balance wheels bounce all the time not just when braking, but I'm going to check with a front end shop and see what they say.
    Thanks
    Frank
  5. Jul 9, 2010 at 3:26 PM
    Frank
    Frank [OP] Member
    Thanks Fred, the shop that put the new drums on said the shoes were good and didn't replace them. Do you think the shoes could be the problem?
    Frank
  6. Jul 9, 2010 at 3:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Welcome to TW.
    Can you give more detail about the vibration? Is it the same if you brake from say 70 mph compared to 15 mph? Can you hear it also? Where do you feel it most? Brake pedal? Steering column? Seat of the pants?
    What are the details about your Tacoma. Which model, year, engine, transmission? How many miles on the truck? Do you have a lift? What size tires? Are you running stock or aftermarket wheels?
  7. Jul 9, 2010 at 3:31 PM
    huntinggunns
    Fred
    Oklahoma
    In progress
    Frank,
    No. All the shoes do are just press out against the drums when you apply the brake pedal. The rubbing together causes the friction to stop the vehicle. This is exaggerated but think of it like this, the drum is turning at very fast speeds with a flat spot on the inside of it. Each time the flat spot passes the stationary shoe that is rubbing against it you will feel the bump that it makes. When the brakes are applied you should feel a faster vibration the faster you are going and it will almost be gone when you are going very slowly. lmk
    Fred.
  8. Jul 9, 2010 at 3:42 PM
    Frank
    Frank [OP] Member
    No it is more noticeable when I'm slowing when I exiting the free way. I do think it is stronger as I get slower, but that may be because I pressing harder closer to the stop sign.
    I don't recall any or much noise.
    I think the brake pedal.
    Which model sr5 double cab
    , year, 2002
    engine, v6
    transmission? Auto
    How many miles on the truck? Just turned 80,000
    Every think is stock. This is a comuter truck. I purchased it new. The only unusual thing is I added a trans disconnect and I have towed it behind my RV. I have about 10,000 miles towing with 4 wheels down.
    ___Frank_______________
  9. Jul 9, 2010 at 3:52 PM
    huntinggunns
    Fred
    Oklahoma
    In progress
    Frank,
    You will feel the pulsation in your brake pedal wether it is the front or rear causing the problem. The movement of the warped drum/rotor causes the pistons in the calipers/wheel cylinders to move and this will transmit back to the pedal. Again, take the drums to a shop to have them checked.
    Fred
  10. Jul 9, 2010 at 3:54 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    You're doing it to yourself by how you are braking.
    You're on the brakes too long too often and there heating up everything and it's warping.
    Want to make them last and prevent this expensive repair from showing up every 6 months ? When you're driving pretend the brakes don't even work and drive accordingly. If you do indead need the brakes use them but limit the time you are on the brake petal. Hard fast braking is more effective the riding the brakes.
    The hills are so big here you can screw up your brakes on a single hill. Learn to drive or change brakes, rotors and drums. Lots.
    If you constantly have brake dust all over you rims you are doing something wrong.
    Maybe not you maybe you lend the truck out to the wife / girlfriend / somebody else.
  11. Jul 9, 2010 at 4:07 PM
    Frank
    Frank [OP] Member
    Hi Trap,
    I won't argue that bad driving habbits can caus the problem. This time the problems existed immediately after new rotors and pads. And still existed after new drums.
    I have owned this for 8 1/2 years and the problem has come up only during the last year.
    I may be a little harder on brakes then the average person, but after this last change I don't think driving is the issue.
    Thanks for the ideas.
    Hi Fred,
    I will try to see if the new drums are bad. I do have a question. If the new drums are bad would the problem feel exactly as it did be for the new ones were installed?
    Thank again to everyone for ideas and suggestions.
    Frank
  12. Jul 9, 2010 at 4:11 PM
    huntinggunns
    Fred
    Oklahoma
    In progress
    Frank,
    Pretty much. You really can't feel the pulsation difference between a drum that is warped .050 and one that is warped .100 thousandths. You just feel the pulsation because they are warped. Anyway, this is a simple and easy check before you drop any more money on the problem. A good brake shop can tell you in a matter of minutes if your drums are warped by mounting them on their brake lathe.
    Good luck, Fred.
  13. Jul 9, 2010 at 4:33 PM
    Trap
    Indego Ink TRD OR
    Thing is the back brake drums where probably warped and you got the front done then that pulsating goofed up the front in short order and then you got the back done.
    Get them to check all the rotors and drums for trueness. Doing one end is pointless. Get them all true then drive like I said, that problem will never come up again.
    Like I said the hills here are so large that you can screw them up on a new set no problem at all on one single hill. If your on flat land drive like it is here and you'll never have a problem ever.
    You can see who changes there brakes lots just by watching other drivers. I make it a challenge here for me personally. Try to get down the hills and not touch the brakes once. Remember you can shift down. Better to shift down than use the brakes. If your foot is not on the gas it's taking no more gas. You get super mileage doing this trick.
  14. Sep 22, 2010 at 5:32 AM
    DeVille
    DeVille Member
    Virginy
    08 Tacoma
    Stock
    I don’t know about your particular Tacoma, but some older BMWs have thrust rods that stabilize the lower control arm under braking. At the end of those thrust rods are sleeved rubber bushings. When those bushings wear (and sometimes if they aren’t worn) the front wheel geometry toes out under hard braking causing a shimmy or vibration. This condition isn’t always detected during an alignment because the weight of the car is not pushing against the resistance of the front brakes. The solution in that case is new thrust rod bushings.
    I’m on this forum specifically because my buddy’s ’08 Tacoma is shaking at the steering wheel, but not necessarily pulsing at the brake pedal, under hard braking. I was curious if something along these lines might be his probable.
  15. Sep 22, 2010 at 7:13 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    It could be your ABS system. It is doing the same thing on our 2000 4 Runner Limited 4x4. One person said it was sensors, and another said the system was just going bad.
  16. Sep 22, 2010 at 7:17 AM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    listen to the man your rotors are warped
  17. Sep 22, 2010 at 8:03 AM
    DeVille
    DeVille Member
    Virginy
    08 Tacoma
    Stock
    Uh, yah, checked that. Not the problem. However didn't check rear drums as suggested above. We'll give that a shot too.
  18. Sep 22, 2010 at 8:31 AM
    Rico
    Rico Member
    Frank I used to have the same exact problem for two years. I put new tires, Brakes and rotor and the vibration would always come back quick.
    Solutions: Depending on how many mile you have DO NOT over look the front wheel barrings. I jacked one wheel in the air and grabbed the 12 and 6 O'clock of the tire position and I couldn't believe the play it had. The barrings were SHOT. Once I changed them out, the vibration has not come back at all when I hit the brakes. Hope this helps.
  19. Sep 22, 2010 at 8:55 AM
    DeVille
    DeVille Member
    Virginy
    08 Tacoma
    Stock
    Hmmm. Sounds like the same geometry going toe out situation. Thanks Rico.
  20. Sep 22, 2010 at 11:07 AM
    i love tacos
    i love tacos Well-Known Member
    St. Louis, MO
    01 PreRunner TRD
    Bull Bar, Hella Lights, AiRaid cold air intake
    If your drums were warped and they replaced them w/ new then your brake shoes would wear unevenly as well.
