Vibration felt in steering wheel going 75-80mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SandToyoda, Sep 23, 2023.
  1. Sep 23, 2023 at 7:09 AM
    SandToyoda
    SandToyoda [OP] Member
    Mark
    2019 Quicksand Tacoma Trd 4x4
    Hello All! On my 3rd gen Tacoma Trd4x4,I’m experiencing a noticeable vibration on my steering wheel going 75-80mph. I’ve noticed this when I added my roof top tent. I have 2 crossbars that attach to the rail system to support the RTT. I’m running factory tire size 265/70/16. I have bilstein shocks 1.5 lift in front using factory coil spring. Bilstein shocks in rear with 2 add a leafs in rear (not sure on brand). I’ve tried carrier bearing spacer no change. I road forced my tires no change. I’ve torqued u-bolts no change. I made sure my axle shim is facing correct direction. I know threads like these probably get redundant but I couldn’t find anything to solve the issue. Thanks again yall.
  2. Sep 23, 2023 at 7:48 AM
    MadJacks
    MadJacks Well-Known Member
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    Who needs fuel economy eh?
  3. Sep 23, 2023 at 8:03 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    You noticed it when you added the roof top tent. Take the tent off and if the vibration goes away then you know where to start.
    Chew, HondaGM and RustyGreen like this.
  4. Sep 23, 2023 at 8:15 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    ^^^ This ^^^
    "Always start where the last guy worked" has helped me solve a lot of problems over the years.
    CaptainBart45 and HondaGM like this.
  5. Sep 23, 2023 at 8:17 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Usually if the tires were already balanced, and not it....you got a bad set of tires.
  6. Sep 23, 2023 at 10:52 AM
    SandToyoda
    Mark
    Should that mess with driveline angle ?
  7. Sep 23, 2023 at 11:15 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    You stated you added the tent and then noticed the vibration.
    The correlation is enough to warrant removing said tent and checking for the vibration.
    Chew likes this.
  8. Sep 23, 2023 at 11:17 AM
    MadJacks
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    You know how when you were a kid and you try and hold your hand out the window, there comes a speed where you can't hold it out anymore ?
    For the Tacoma with a RTT, it appears to be 75-80mph.
    CaptainBart45 and Chew like this.
  9. Sep 23, 2023 at 11:47 AM
    SandToyoda
    Mark
    LMAO That’s the best way to describe that.
    Even so if the RTT sits flush with the top of the roof ?
  10. Sep 23, 2023 at 12:01 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    check the alignment...maybe it's off a tad.
