vibration from 25 to 45 MPH
Discussion in 'Suspension' started by Tacomasnow, Jan 21, 2009.
  1. Jan 21, 2009 at 10:44 AM
    Tacomasnow
    Tacomasnow [OP] Member
    Idaho Falls ID
    09 Tacoma TRD Sport
    silver paint with a 3" lift followed by 17" moto metal wheels and 32 BFG all terrain. JBL Adio
    maybe someone can help!
    I put a three inch lift on the front of my Tacoma and a 1 inch on the back to make it dead level.. i went with Ready lift suspension, after installed it looks great! but now i have a vibration that's driving me crazy from 25 to 45 MPH
  2. Jan 21, 2009 at 4:37 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    u might want to look into getting the toytec rear axle shims or doing the carrier bearing drop. i did the shims on my 07 when it had the vibe and it took it away
  3. Jan 21, 2009 at 4:49 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    ^ Yep, JH is all over it.
  4. Jan 21, 2009 at 4:50 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    good luck man.i have the same thing.i was going to try this w/e some diff. stuff but just had a major medical issue with my pops,(bad stroke) and major bummed out, so that might put the dampner on things for a while.:mad:i do know this isnt the first thred on this topic.snowboarder has been working on this(hes smart).so u might wanna give him a pm.im sure he will help out. yeah and what JH said
  5. Jan 21, 2009 at 5:52 PM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    Thanks for the kudos pataco and I'm so sorry to hear about your pops.
    Tacomasnow, try the carrier bearing spacer as JHodge83 suggested and see if that helps. Did you install front diff drop spacers with your lift?
  6. Jan 21, 2009 at 6:25 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    and if all else fails, get a Tom Woods Drive Shaft :thumbsup:
  7. Jan 21, 2009 at 7:00 PM
    Tacomasnow
    Idaho Falls ID
    09 Tacoma TRD Sport
    hey thanks everyone for the info i ended up getting some procomp 2 degree shims for the rear axle so i will give them a try.. which way would you put the shims? there were no directions. and for SnoBoarder, yes i did install the diff drop spacers.. the vibration is not terrible but its like you have over sized tires on, when you actually don't.
  8. Jan 21, 2009 at 7:12 PM
    jhodge83
    SC
    the shims go in w/ the fatter side to the rear and the pointy side pointing towards the front of the truck....simplest terms. they go under the leaf pack.
  9. Jan 21, 2009 at 8:50 PM
    SnoBoarder
    Lost
    Did you have a chance to drive it for a day or 2 before installing the front diff drop?
  10. Jan 21, 2009 at 10:30 PM
    Tacomasnow
    Idaho Falls ID
    09 Tacoma TRD Sport
    haha that's a great way of explaining it, i appreciate the info jhodge83.
    SnoBoarder no, i never got a chance to give it a spin with the diff drop spacer removed i didn't think of that working. Does it it help? it almost seems like the vibration comes from the front end and not the drive line. I've just figured that's the problem because of what i have been reading on it. Let me know if that's something i should be trying. Thanks!
  11. Jan 22, 2009 at 4:05 AM
    SnoBoarder
    Lost
    I've tried a front diff drop with a lifted 05 and an 07, with the toyota 2 piece rear driveline and with a Tom Woods 1 piece, and I think the front diff drop is worthless and causes more vibrations and droning noises for most people than it cures. I removed my diff drop and that reduced the lower speed vibrations and droning each time.
    Your rear driveline u-joint operating angles are definatley out of spec after the lift. A lot of those rear driveline vibrations ripple up the driveline where you sense them up front. The carrier bearing spacer has helped also.
  12. Jan 22, 2009 at 4:18 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    I hear what you're saying:
    But, the diff drop will lessen the angle on your front CVs and is highly recommended by any lifted 4x4 owner on this board to extend the life of your CVs.
    For driveline vibes, get the shims or carrier bearing drop (or a TWDS). :thumbsup:
  13. Jan 22, 2009 at 5:54 AM
    SnoBoarder
    Lost
    I understand that to be a general recommendation, but I disagree with it from research and personal experience.
    Some lift kit manufacturers have stated that the CV angles are not severe with the added 2-3 inches of front lift and that the front diff drop is really not necesssary and no longer recommended. I happen to agree with those statements.
    I've installed the front diff drop multiple times, and compared CV angles. Even though they are 1 inch drop spacers, they don't lower the front diff by 1 inch, instead they rotate the front pinion angle a few more degrees upward (unnecessary) and add only a slight amount of overall lowering, perhaps 3/8 of an inch, which has very little effect on sparing the CV angles from significant wear and tear. Vibration and droning complaints are fairly common with the front diff drop which is why I checked to see if he had driven it without it. FWIW, I had almost 90,000 miles on my old lifted 05, with no diff drop and no CV issues, and 35,000 on my lifted 07 with no diff drop (that's a whole other story) and no issues. I also have a 1-piece from Tom, great investment.:thumbsup:
    I would make correcting the rear driveline angles top priority. It usually results in reduced or at least more acceptable levels of vibrations, without the front diff drop. Just my 2 cents.
  14. Jan 22, 2009 at 6:15 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Thank You!!! I have that drone that feals like it is up front, worse when very cold. I thought it was the front barrings??? I'm going to try taking out the front diff drop and get a carrier baring drop instead (when it warms up a bit).
    Again, Thank you, that makes perfect sense.
  15. Jan 22, 2009 at 3:13 PM
    Tacomasnow
    Idaho Falls ID
    09 Tacoma TRD Sport
    Alright well i'm going to go with SnoBoarder it seems like you know what your talking about.. once again thanks a lot for this valuable info.
    one more question SnoBoarder what's the pros and cons on getting this Tom Woods drive shaft?
  16. Jan 22, 2009 at 3:24 PM
    SnoBoarder
    Lost
    Thanks for the kudos, but this info's only good if it actually helps cure your issues. The 1 piece is so much easier to measure and correct the working angles, plus there are no adjustments, it just bolts on. It helps with take off shudder too.
  17. Jan 23, 2009 at 9:07 AM
    Budisweiser
    Budisweiser Member
    fort scott, kansas
    2008 tacoma 4x4 DC off road.
    I to have the vibe in the front that start during the cold weather. Have the tw dc shaft with 2.5 degree shims that cured every vibe at first. Ran awesome then it got cold. My vibe is from 30-45 in the front left. Been to toyota dealer and everything "looks good". stated probable lift vibe. I strongly feel it's the diff output shaft on the left as others have stated. This shaft must be on the side of short to begin with and cant handle the cold weather and a lift (shortening the shaft). Other theroy is the diff lube is sub par causing vibes during the colder weather. It reached 65 here today and she rode nearly vibe free. I also lowered the air pressure in my ruggeds to 35psi from 40psi. Lowering my billy co's to 2" of lift lessened the vibe a little also. My vibe is a very mild thump, thump, thump, You mostly feel it and cant really hear it. :confused:
    2008 TRD offroad DC 4x4
  18. Jan 23, 2009 at 10:15 AM
    sonjay
    sonjay Well-Known Member
    ^ I have a similar vibe Budisweiser, I jacked the truck up from under the lower A arm, and when I rotate the tire by hand you can hear the noise in the diff? You could try the same thing. I'm going in today to see what Toyota says about it. I've read that a few people have had the front diff replaced with similar issues.
  19. Jan 23, 2009 at 12:43 PM
    SnoBoarder
    Lost
    Your 2.5 shim pushed your rear pinion angle upwards another 2.5+ degrees and with your 1 piece drive shaft, you'll need to take some new measurements as the angles may have changed over time.
    Edit: since you have a double cardan 1 piece, your double cardan joint should be up at the transfer case and the single cardan side should be down at the rear axle. The angle between the pinion and the driveshaft at the single cardan side has to be 0 degrees, so the 2.5 is either over or under correcting, you'd have to measure both angles and see which way you need to go.
    The "thump" description doesn't exactly match what we've been talking about as far as driveline vibrations, so any kind of "thump" is likely another issue to troubleshoot :confused:.
  20. Jan 23, 2009 at 12:56 PM
    SnoBoarder
    Lost
    Sonjay-I did it, no helpers, just me. Dakars and shocks, 4 hours. Thanks for all the pm info!!!
