Vibration from front end help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CTeunuch, Feb 22, 2015.
  1. Feb 22, 2015 at 10:38 AM
    CTeunuch
    CTeunuch [OP] Member
    Patrick
    MA
    08 TRD Off-Road DCSB 6spd
    Nothing worth mentioning yet...
    Hey guys, I have a 2008 DCSB TRD offroad. I'm getting some bad vibes from my front end, and when I rolled under and checked it today I found the CV shaft on the drivers side is moving around inside the diff quite a bit. There doesn't look to be any play in the shaft itself, just where it slides into the diff. Is there a bearing in there that supports the shaft that could be wiped out? Or some sort of retaining clip missing? Any help is appreciated.
  2. Feb 22, 2015 at 10:40 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Feb 22, 2015 at 10:41 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  4. Feb 22, 2015 at 10:44 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    ^^^^ x2
  5. Feb 22, 2015 at 11:52 AM
    CTeunuch
    Patrick
    MA
    Thanks guys. How long did it take you(roughly) to replace the bearing? Did you do both sides, or just the drivers side? If it's pretty loose now, you think I'll be alright waiting to do it until next weekend? I'd hate to wreck the diff.
  6. Feb 22, 2015 at 11:54 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    There is only one on the drivers side. The passenger side is a ball bearing. Some people have gone a long time with it not fixed. But I don't know the negative effects of that.
