Vibration from rear end at 45mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whitebread, Feb 19, 2010.
  1. Feb 19, 2010 at 6:02 AM
    whitebread
    whitebread [OP] Well-Known Member
    Raleigh, NC
    2011 4x4 DCSB TRD Off-Road
    Leer 100XL and a bunch of off-roading scars.
    I was hoping you guys could lend some input. I have been experiencing this issue for the past 5k miles. When driving in 5th gear between about 42mph and 46mph (~1600 RPM?) there is a shaking coming from the back end that can be felt in the seat.
    • Put the truck in neutral and it appears to disappear a few seconds after, but not immediately.
    • Had the tires balanced and it didn't help any.
    • I don't recall experiencing this before having the suspension TSB.
    • It appears to be more prevalent when the truck is cold.
    • If briskly accelerating through the problem speeds there is no vibration felt.
    • On some road surfaces you can't feel the vibration.
    • I have adjusted tire pressures in both directions and it didn't make much difference.
    I was planning on installing my lift tonight and having my tires put on tomorrow, but I am a little worried about the dealer blaming the lift...so I want to get this issue resolved first. The dealer will be checking it out on Tuesday, but to be honest, I have very little faith in them so I want to gain as much information as possible.
    My next step is to measure drive-shaft angles, but with a stock suspension it doesn't make sense that would be the cause.
    Any input is greatly appreciated.
  2. Feb 19, 2010 at 6:41 AM
    Sack17
    Sack17 Well-Known Member
    Andrew
    Sanibel, FL
    05 Tacoma DBL Cab TRD Sport 4x4
    Bed lights Blacked out sport wheels blacked out emblems BHLM Spidertraxx 1.5" wheel spacers factory roof rack custom yakima wind fairing w/ PIAA off road lights up top snowboard/ski rack surf board pads fog light mod custom interior cup holder l.e.d. lights Bestop topper custom L.E.D. rear facing lights Maglite mod (2 front seats) 3.25" in the front 2.5" in the rear 6 Hella 500ff's (w/ Silverstar's) Silverstar Ultra's in headlights Silverstar Ultra in fogs (retro-fitted 65w 9005's) Hi-Lift (mounted on side of bestop) Shovel (mounted on side of bestop) custom 1.5" body lift
    The only thing I could think of, and keep in mind I'm no mechanic, but I would try and check the nuts on the rear U bolts. Maybe they didn't tighten them tight enough which is causing the vibration.
  3. Feb 19, 2010 at 7:29 AM
    whitebread
    Raleigh, NC
    Good thinking...that didn't cross my mind.
  4. Feb 19, 2010 at 9:16 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    So the only change was the TSB leaf springs done by the dealer? If so, take it back and get it fixed. It could be loose u-bolts or the leaf springs are not seated correctly.
  5. Feb 19, 2010 at 9:28 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    x10!
  6. Feb 19, 2010 at 10:08 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    u-joints.
  7. Feb 19, 2010 at 11:03 AM
    whitebread
    Raleigh, NC
    I did check the leafs and they appear to be seated correctly. I did not check the torque on the nuts.
    aficianado, I too am wondering about the u-joints.
  8. Mar 3, 2010 at 4:54 PM
    whitebread
    Raleigh, NC
    So the dealer said it was the "firm ride" they warned me about before putting on the TSB spring pack. I thanked them for their time and left still wondering what was causing the vibration.
    Anyway, installing my lift fixed it. I didn't use the rear shims or bearing drop either. Maybe it was the new tires, alignment, or re-torquing everything; who knows. I am just glad it is fixed.
