vibration help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tisher49, Mar 29, 2012.
  1. Mar 29, 2012 at 8:26 PM
    tisher49
    tisher49 [OP] Well-Known Member
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    K&N Air Filter, Westin Bull Bar with PIAA fog lights, Retrax cover, Alpine Head unit with I-Pod interface, maglite mount, Color matched grill surround w/ Grillcraft mesh
    I recently got in a wreck avoiding a deer, stupid I know, should've just taken out the deer. Essentially I did a 180 and slammed sideways into a tree. The initial estimate I got from the local shop said I needed a new axle, but then they said it was just a bent wheel and the axle was fine.
    When I got the truck back I noticed it seemed to be vibrating at low speeds but it isn't very noticeable and is tough to tell if it is just rough pavement I am driving on. It is very noticeable at 60 mph and above, and is what I would call a harmonic vibration. The vibration lasts for about half a second, goes away, and then comes back and keeps repeating this process at about 1 second intervals. The faster I go, the shorter the time in between these vibrations. They are audible and sound like tire rubbing but I have checked the tires and they seem to be clear. I also noticed that if I am going above 60 mph and the vibration is there, but I am taking a long left hand curve, the vibration goes away, which makes me think it is something to do with the steering components. I can feel the vibration in the gas pedal if that helps.
    I also noticed that they had only replaced my springs with the 3 leaf pack, even though I had the TRD shocks and the 4 leaf pack. So I thought that might be the cause but after getting a 4 leaf pack put on, the vibration is still there.
    At this point I am going to bring it to a Toyota dealer and see what they can do but wanted to see if anyone had any ideas on here, so I don't get hosed by them. I have to imagine if it was an axle issue it would be noticeable at all speeds and would frankly be much more violent vibrations. My truck doesn't shimmy or shake, but the vibration is definitely noticeable.
    Any ideas or thoughts about how to approach the dealership about it would be greatly appreciated. Thanks in advance.
  2. Mar 29, 2012 at 8:29 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Oddly enough even without crashing into something, I have this very same vibration. With mine it feels like it goes from the back of the truck to the front. Same thing, comes for a few seconds, then goes away like clockwork.
  3. Mar 29, 2012 at 8:38 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Funny, I've had exactly what you describe since day 1. I've repeatedly taken it in, and nobody can hear or feel a thing. P's me right off!
    Are you two guys driving manuals by chance?
  4. Mar 29, 2012 at 8:51 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    yep 6 spd... sorry to hear you guys have the same issue without even had something that might cause it.
  5. Mar 29, 2012 at 8:57 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Nope, auto.
  6. Mar 29, 2012 at 8:58 PM
    DWreck
    Derek
    Las Vegas, NV
    There lies the problem. These 6 speeds are shit.!
  7. Mar 29, 2012 at 9:09 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    I've loved mine so far and minus this, have had no issues so far. The vibration doesn't seem to change at all if I change gears though. Seems to be more based on the speed I am going.
  8. Mar 29, 2012 at 9:20 PM
    DWreck
    Derek
    Las Vegas, NV
    Yup. You are lucky I guess. I'm on my second clutch and 3rd t-o bearing. 40k miles. My neighbor has an FJ with the same tranny, his literally flew apart. The whole tranny.
  9. Mar 30, 2012 at 3:48 AM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    yikes that sucks man. This truck is my first vehicle with a manual and I don't think I can go back to auto. I really hope it's not something the gearbox or anything expensive
  10. Mar 30, 2012 at 10:23 AM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    anyone else out there have some ideas?
  11. Mar 30, 2012 at 8:10 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Sounds like it could be a wheel bearing, especially with the way it changes on cornering. The first one I'd check is the one that took the hit.
  12. Mar 30, 2012 at 9:16 PM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    Thanks I'll have to check it out. From watching some videos online it seems like if I take the wheel off, and the wheel bearing has any wiggle in it this could be the issue. Does that sound like the right way to check it?
  13. Mar 30, 2012 at 11:20 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    If you can get movement in the bearing or if you feel any roughness when turning the hub then you have definite evidence of a bearing failure. But, wheel bearings can be tricky, just because it passes the above testing does not always mean it's fine. A cracked race or localized pitting in the bearing may not show up until there is load on the bearing, and of course, its very hard to inspect it under those conditions as the truck is moving. If nothing turns up easily, I'd probably replace the one that took the hit. If it bent the wheel, there's a good chance the bearing is damaged. Which wheel took the impact? The right rear?
    You don't have to remove the wheels to check the wheel bearings, just jack it up, and use the wheels as leverage to try to get movement.
  14. Mar 31, 2012 at 3:50 AM
    tisher49
    Alex
    Orange, Virginia
    '08 4.0L 4x4
    Awesome thanks so much. Actually it was the back left wheel. I was thinking the same thing that if the wheel got bent, something else back there probably got F'd up too. Thanks again for the help.
