Vibration help!!!
Discussion in 'Suspension' started by abnranger80, Jul 21, 2012.
  1. Jul 21, 2012 at 5:04 PM
    abnranger80
    abnranger80 [OP] Member
    Nick
    Waynesville NC
    TRD
    ARB Bumper, M8000 Warn, 6" Procomp lift, 17" procomp wheels, 37" Mickey Thompson MTZ, King Coilovers.
    I just installed a full ome setup, 886's, dakars the whole deal. i went ahead and put on the carrier drop and thought everything was gona be cool but have vibrations at take off. so i ordered some shims slapped them bad boys on and still have vibrations at take off. any suggestions cause i cant find anything on here and ive looked a while.
  2. Jul 21, 2012 at 5:13 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    carrier bearing drop should easily do the trick!
    edit NVM i thought when i initailly read it it said front diff drop....
    idk lol
  3. Jul 21, 2012 at 6:03 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Did the shims quiet it down a little? Are you 4 wheel drive? I recently installed the rear dakars, shims and the CB drop also, I have no vibes. Drives better than stock. How high is your frontend? Are you missing wheels weights? that will make a vib also. Tires rotated? Just thinking of the easy fix. How long has it been sence you installed the lift? I just retightened all my rear suspension down today, nothing was loose. just a thought.
    Brett
