VIBRATION HELP
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Smithmd88, Aug 8, 2022.
  1. Aug 8, 2022 at 5:02 PM
    Smithmd88
    Smithmd88 [OP] Member
    2018 DBL CAB 4x4 TRD OR
    2018 4WD DBL CAB Stock no lift!
    Bought a couple weeks ago and now I see why someone else traded it in...
    Anyway here are the symptoms.
    I'm getting a vibration buzz when I step on the accelerator.
    This occurs in low cruising RPMs under load. I step on the gas and I get a buzz. I let of the gas the buzz goes away instantly.
    Here's a scenario.
    Driving on the highway going about 65mph-70mph at 1800-2000 RPMs and I get a buzz when I have my foot on the pedal. I shift down into S4, RPMs jump to about 3,000 RPMs and it's smooth as butter. I shift into 5th and buzz becomes noticeable. Shift into 6th and it gets worse.
    Driving on the side streets it's essentially the same except it will occur at lower MPH but at the same RPM range. Shift into S4 at 45mph and I will get the same buzz as if I was in 6th grade at 65mph.
    Low RPM under load vibration in the 1800-2000 RPM range.
    I'm thinking torque converter.
    Any thoughts?
    I have 58,000 on the odometer. I'm hoping the dealer will take care of any drivetrain work but I'm sure I will get the old "it's normal" excuse.
    This is definitely not normal. I'm a car guy and I rebuild classic cars. I know my way around cars and I know there is something clearly wrong.
  2. Aug 8, 2022 at 5:03 PM
    GatorBodine
    GatorBodine Well-Known Member
    Jay
    23' 4 cyl.
    Get it in before that 60,000 mile powertrain warranty is up
    Aqualoon and zoo truck like this.
  3. Aug 8, 2022 at 5:09 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Could be the the needle bearing on the front diff. Find a good location and try 4H. If the vibration changes behavior, good chance it's the needle bearing.
  4. Aug 8, 2022 at 5:13 PM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    Sounds like when your torque converter goes into lock up is when it starts. I would look at the torque converter.
  5. Aug 8, 2022 at 5:23 PM
    Smithmd88
    This is what I'm thinking too.
    You live in the white mountains? Lucky you!
  6. Aug 8, 2022 at 5:24 PM
    Smithmd88
    Forgot to mention it's totally stock. No lift
  7. Aug 8, 2022 at 5:48 PM
    Midnight beauty
    White mountains AZ
    Yep. Wouldn’t change it for the world.
  8. Aug 8, 2022 at 6:01 PM
    Smithmd88
    I'm in Phoenix in the heat hating my life with a vibrating Tacoma. I'll be headed up in a few weeks with my 2001 Silverado because I literally hate driving this thing.
  9. Aug 8, 2022 at 6:05 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    A 4yr old Tacoma with NO mods? IMPOSSIBLE! I call bullshit on this claim. Stop your lies, sir.
  10. Aug 8, 2022 at 6:21 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Have you tried putting it in 4 Hi to see if the vibration goes away?
  11. Aug 8, 2022 at 7:57 PM
    Smithmd88
    No. I will try that in the morning on the way to the dealership lol
  12. Aug 9, 2022 at 5:54 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Or if still under the dealers warranty you bought the truck from, have them fix it.
