Vibration @ Highway Speeds
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blues0010, Dec 7, 2015.
  1. Dec 7, 2015 at 6:35 AM
    Blues0010
    Blues0010 [OP] Well-Known Member
    Ben
    Boise, ID
    2001 Tacoma SR5
    I sometimes get a pretty strong vibration that seems to come from the rear of the truck. It doesn't occur all of the time but will only occur if I'm going at least 55/60+ mph. Usually, if I slow down below 50 and then re-accelerate, the vibration goes away.
    I've had the truck for a few months and have spent several hours on the highway but have only had this happen about 4 times.
    Any ideas what this could be or how I could fix it? Let me know if you need more information.
    Thanks,
    Ben
  2. Dec 7, 2015 at 6:42 AM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Go have your tires road forced balanced, that will be a start.. If that doesn't fix it, it will at least help narrow down. Do you have new tires?
  3. Dec 7, 2015 at 6:48 AM
    Blues0010
    Ben
    Boise, ID
    2001 Tacoma SR5
    They aren't new and I haven't had them balanced since I've owned the truck.
  4. Dec 7, 2015 at 6:50 AM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    I'd go have them road forced.. Like I said it'd be a start, might fix it.. Tires can do weird things.
  5. Dec 7, 2015 at 7:56 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Driveline u - joints. Check them.
  6. Dec 7, 2015 at 12:27 PM
    Blues0010
    Ben
    Boise, ID
    2001 Tacoma SR5
    That seems likely as the vibration doesn't seem to be biased towards any one corner of the truck. What do I need to check when I'm inspecting them?
    Do i just need to lube them or do I need to take them off?
    Thanks
  7. Dec 7, 2015 at 1:00 PM
    CD20H
    Ben
    North Texas
    The best way to check the ujoints is to remove the drive shaft from the truck. Mark the rear bolt flange and driveshaft flange so it goes on exactly the same way it came off, remove bolts from the rear flange and center support bearing ( if applicable ). Once it's on the ground, grab the drive shaft on each side of the ujoint and twist. ANY movement in the ujoints besides normal articulation is a sign of needing to be replaced. Rule of thumb: Replace them all if one is bad. Usually when one is bad......the rest are on there way to going bad.
  8. Dec 7, 2015 at 1:40 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I second the U-Joints. See how much slop you have in that carrier support bearing.
  9. Dec 7, 2015 at 8:27 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Juat grease the u-joints. 2 shots should be fine. push the driveshaft up at the center support, it should be quite firm. If it travels easily more than 3/8 inch, it's bad.
  10. Mar 21, 2016 at 9:01 AM
    Blues0010
    Ben
    Boise, ID
    2001 Tacoma SR5
    Resurfacing this.
    Previously, I replaced a tire that had a sidewall bulge and greased my drive line. That solved the problem for a few thousand miles.
    Now, I'm experience vibration starting around 40-45mph. This vibration increases with speed. I'm also experiencing some squeaking/chirping at lower speeds specifically when transitioning between accelerating and engine breaking.
    New U-joints are on the list for sure. Is there anything else that I should be looking into?
  11. Mar 21, 2016 at 10:32 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sounds like u-joints and centerbearing..
  12. Mar 21, 2016 at 1:09 PM
    CD20H
    Ben
    North Texas
    This^
  13. Mar 30, 2016 at 6:22 PM
    Blues0010
    Ben
    Boise, ID
    2001 Tacoma SR5
    @wilcam47 @CD20H
    Replaced the U-Joint and the truck is running great again. Thanks for the input
  14. Mar 30, 2016 at 6:26 PM
    CD20H
    Ben
    North Texas
    :thumbsup: You are very welcome.
