Vibration in 1st gear only (after lift)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VXEric, Jun 27, 2022.
  1. Jun 27, 2022 at 3:49 PM
    VXEric
    VXEric [OP] Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Yet another vibration post.
    Just lifted 2" or so with toytec springs, bilstein 5100s and add a leaf. About 250 miles later I started getting a pretty strong vibration only in the shift knob as I would pull away from a stop in first gear. Doesn't happen in any other gear and I don't feel it in the steering or in the seat. Only the shifter shaking like hell.
    I did a diff drop over the weekend and that helped a little but it's still there.
    Needle bearing?
    Need more diff drop?
    Normal and I didn't notice it until after the lift?
    https://youtube.com/shorts/JBp57ajsLkY?feature=share
  2. Jun 27, 2022 at 4:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t it is the needle bearing because you’re description doesn’t fit it’s symptoms.
    But you can put it in 4WD and see if it persists. If it goes away, I’d be looking at the needle bearing.
    If it were my guess, I’m going to say it driveshaft angle. (Rear)
    VXEric[OP] likes this.
  3. Jun 27, 2022 at 4:54 PM
    DG92071
    DG92071 Well-Known Member
    Check: engine mounts, transmission/transfer case mounts, if those are good I'd go to the rear driveshaft carrier bearing and inspect it, if it looks good I'd change the angle of it with a kit.
    VXEric[OP] and TnShooter like this.
  4. Jul 5, 2022 at 5:05 PM
    VXEric
    Eric
    Worcester, PA
    Quick update. Installed the carrier bearing drop and it helps some but not completely gone. I already have the ECGS bushing, so we'll see if that gets rid of it the rest of the way.
