Vibration in floorboard, gas pedal and steering wheel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Laggy2017, Oct 16, 2017.
  1. Oct 24, 2017 at 4:34 PM
    #41
    ShiggityShiggity
    ShiggityShiggity Member
    2017 Tacoma TRD OR DCSB
    I have a 2017 TRD OR DCSB and I experience the same issue.
  2. Oct 24, 2017 at 4:35 PM
    #42
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    Quite a few users have reported your exact issue, including myself (my thread listed below). I too have already wanted to get rid of the truck becase if the issue. One user stated his driveshaft was missing one of the balance weights from the factory and getting the driveshaft replaced helped but didn’t completely get rid of the issues.
    I still have yet to figure out my cause but you can view my thread with info and videos here: https://www.tacomaworld.com/threads/odd-vibrations-2017-tacoma-trd-sport.496393/
    Another users thread: https://www.tacomaworld.com/threads/thoughts-for-vibration-65-85.512204/
  3. Oct 25, 2017 at 8:34 AM
    #43
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    You guys know that this is issue with the 2nd gen trucks also right? Toyota won't be changing anything.
  4. Oct 25, 2017 at 9:44 AM
    #44
    weefek
    weefek Well-Known Member
    J
    2017 OR ACLB
    You mean Toyota didn't put self - tightening wheel lugs on the 3rd gen??? what a fuckin TURD !
  5. Oct 25, 2017 at 3:39 PM
    #45
    Laggy2017
    Laggy2017 [OP] Member
    Laggy
    2017 Tacoma 4x4 trd sport
    After 3 days of being at Toyota, they are still not able to replicate the vibration. They just want me to come pick it up and take it home.
    tcjacado and bshammer0 like this.
  6. Oct 25, 2017 at 9:39 PM
    #46
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Gotta tell them you want to ride with the shop foreman.
  7. Oct 25, 2017 at 10:06 PM
    #47
    Murrdogg619
    Murrdogg619 Active Member
    Honolulu, Hawaii
    2017 Tacoma Double Cab TRD Off-Road 4x4
    TracRac bed racks, Tint
    I went out of town for 3 weeks and when I came back and started driving my truck I started noticing this vibration which seems to happen between 2,000 to 2,500 rpms. I only have 2700 miles on this truck so far so this is very concerning. I will continue to monitor it for now but I have no idea what's causing it. Truck is all stock 2017 off road double cab.
  8. Oct 26, 2017 at 4:14 AM
    #48
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    On most trucks this is harmonics and a poorly tuned engine/exhaust. Look for any insecure cables underneath the cab close to the drivers seat and secure anything that looks like it could rattle. An exhaust damper helps a bit as well, and I found premium fuel also smooths vibes out. And then as you may have seen there is the aftermarket tune some have done (OVTune) that radically smooths everything else out. Only bit of consolation is that there is likely nothing WRONG with your truck but it is annoying and there are ways to address it
    Patrick1046 and BlkTaco47 like this.
  9. Oct 26, 2017 at 4:41 AM
    #49
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    thankfully I never felt on either of my 2nd gens, would have never made the jump if I
    did or if it popped up in the test drive. Hoping for some ovtune smoothness soon!
  10. Oct 26, 2017 at 5:02 AM
    #50
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Why are you spending your time and money to fix a problem that is clearly a defective park from Toyota. Toyota is putting out total crap.
  11. Oct 26, 2017 at 9:15 AM
    #51
    swimmer
    Tucson
    2016 TRDORAC4WD
    Despite the many attempts to hijack this thread otherwise, the OP has the front differential needle bearing problem, which is a carryover issue from the 2nd gen. Ovtune won't do shit for that
    bshammer0 likes this.
  12. Oct 26, 2017 at 9:19 AM
    #52
    bluenv
    bluenv Well-Known Member
    I never had this problem on my 2nd gen OR, and if this was the case, why doesn't the dealer just fix it?
  13. Oct 26, 2017 at 9:36 AM
    #53
    swimmer
    Tucson
    2016 TRDORAC4WD
    Yeah, most owners don't have the problem especially if their truck is not lifted. Very few non-lifted 3rd gens have the problem. Mine was an exception. I suspect many owners also aren't sensitive enough to notice it. Toyota can't fix it permanently because it's a design issue and only a tiny fraction of stock trucks have the problem and if you try to get Toyota to accept responsibility for a problem you've got with your truck after lifting it.....
    There are many, many threads in the 2nd and 3rd gen section discussing this front diff vibe/ECGS bushing issue.
  14. Oct 26, 2017 at 12:35 PM
    #54
    bshammer0
    Brandon
    Nashville, TN
    Indeed. if it goes away in 4Hi no question about the root cause.
  15. Oct 26, 2017 at 2:01 PM
    #55
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Seems like you didn't follow any of the basic advice because I think I speak for everyone on here when I say you should've never bought a truck with a shitty dealer installed lift....
    You bought a truck with a 3" spacer lift and now wonder why it rides like shit and is having problems?? Come on now....
    I mean I don't know FOR SURE if you have a spacer lift but every dealer installed lift I've seen is some shitty spacers with stock control arms so I'm assuming that's what you got as well.
  16. Oct 26, 2017 at 2:16 PM
    #56
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    1st gens too
  17. Oct 26, 2017 at 4:12 PM
    #57
    splatrd
    splatrd Member
    2016 Tacoma TRD Sport ACLB
    3 Inch lift
    Has anyone heard of a free wheel/manual locking hub kit for these trucks? I saw one for Chevys, but can't remember now where. That would solve all the problems with vibration since the front axles and gears would be stationary until 4 wheel drive is required. I would be ok with manual engaging the hubs when I know I will be needing 4 wheel drive.
  18. Oct 26, 2017 at 4:51 PM
    #58
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Torque converter lock-up per Toyota
  19. Oct 27, 2017 at 7:06 AM
    #59
    Laggy2017
    Laggy
    I did twice, the problem is the vibration is felt mostly through the gas pedal and the drivers side floorboard, so I felt it but the passenger could not. Very frustrating telling someone in the car youre feeling something and they don't believe you.
    They "cant replicate" the issue. After 4 days of it being in their shop they couldn't replicate it, but as I drove off the lot, there it is, hmmmm hmmmm hmmmm
  20. Oct 27, 2017 at 8:47 AM
    #60
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    You didn't let the foreman drive?
