Vibration in front end while braking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brobrady, May 20, 2017.
  1. May 20, 2017 at 11:22 AM
    Brobrady
    Brobrady [OP] Well-Known Member
    Does anyone else have vibrations in the front end while applying a small amount of pressure to the brakes? I have 21,000 miles and have just started noticing these vibrations.
  2. May 20, 2017 at 11:25 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    21k, definitely enough time to warp rotors. Get the rotors resurfaced if tolerance still in spec. Just take it to dealer. They may warranty this.
    InfernoTonka likes this.
  3. May 20, 2017 at 11:28 AM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Rumble strip vibes?
    Or buzzy brake pedal?
  4. May 20, 2017 at 11:29 AM
    Brobrady
    That's what I was figuring. How long should rotors last under normal use?
  5. May 20, 2017 at 11:30 AM
    9TRDTCO
    9TRDTCO Well-Known Member
    My rotos warped at 17k miles, dealer resurfaced under warranty.
    GPsevinSixx likes this.
  6. May 20, 2017 at 11:31 AM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    It varies. Depends on your driving and braking. Mine are still decent, I am waiting on my wheels bearings before I change all of my brakes.
    Some people have warped there's in 20k, others never have. Just varies
  7. May 20, 2017 at 11:32 AM
    GPsevinSixx
    Ros Angerus
    Long while. Depends how hard you are on them with driving conditions they're subjected to. Go by minimum thickness and cracking.
    Usually can go through at least 3 sets of brake pads before changing them.
    outlawtacoma likes this.
  8. May 20, 2017 at 11:34 AM
    Brobrady
    I was going to have it addressed at the 25,000 mile service. Hopefully it will be covered under the 30,000 mile warranty.
  9. May 20, 2017 at 11:36 AM
    Plain Jane Taco
    Plain Jane Taco ALL human beings deserve equal treatment
    USA
    Improper lug nut torquing can cause rotor warpage.....either too tight and/or inconsistent torque between the lugs.
    Quite common
    nDub, InfernoTonka and outlawtacoma like this.
  10. May 20, 2017 at 11:41 AM
    tacoflavoredkisses1
    You guys are jumping to rotors.
    OP, Is it like a cell phone buzzing / pulsating feeling? A bunch of us have had issues with the brake accumulator on these trucks.
    ikon4x4 likes this.
  11. May 20, 2017 at 11:41 AM
    GPsevinSixx
    Ros Angerus
    ^^ this too, but I remembered you had small lugnuts before. :rofl:
  12. May 20, 2017 at 11:43 AM
    Plain Jane Taco
    USA
    Yes.....yes I do
    GPsevinSixx[QUOTED] likes this.
  13. May 20, 2017 at 11:50 AM
    Brobrady
    Not a buzzing. More of a vibration that causes the front end to bounce up and down under the right conditions.
  14. May 20, 2017 at 11:54 AM
    GPsevinSixx
    Ros Angerus
    Bouncing up and down describes something else, like out of balance tires. But you'd feel it in the steering wheel with either one. ABS, you'd feel in the pedal mostly.
  15. May 20, 2017 at 12:02 PM
    tacoflavoredkisses1
    Does it happen on decel between 25mph and 0? Does it feel like a rumble strip ?
  16. May 20, 2017 at 12:25 PM
    Brobrady
    It happens usually under 25 mph. It doesn't feel like rumble strips it's not as sharp or distinct as that.
  17. May 20, 2017 at 12:30 PM
    whiskey101
    whiskey101 Well-Known Member
    Clarksville, TN
    '17 Super White 4WD TRD Off-Road
    Leer 100XQ
    My brand new 2017 has a little front end vibration when light braking. I was waiting for first service to mention it to the dealer.
  18. May 20, 2017 at 2:47 PM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    I agree with the other. If you feel it in your pedal it is the rotors most likely. If you feel it in your steering wheel it is the tires/wheels. They need re-balancing.
  19. May 20, 2017 at 3:09 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    ^^This^^
    Simple and most common OP, more so If you've had your tires rotated recently by shop or impact wrench.
    IDK what your skill lvl is but if you can change a tire as per owner manual you can check it.
    Or a trip to the stealer and insist they use a torque wrench, but good luck with that.
  20. May 20, 2017 at 3:23 PM
    Brobrady
    I have a torque wrench and can check it. Anyone know the specs?
