Vibration in gas pedal and cab with a wa wa wa sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdub105, Dec 13, 2012.
  1. Dec 13, 2012 at 4:47 AM
    cdub105
    cdub105 [OP] Active Member
    Florida
    05 Tacoma Access Cab 4x4
    For the last few weeks I've had a revolving wa wa wa sound where I could feel a vibration in the gas pedal that matched with the noise. Took it to two different shops and finally was able to point it out to one. Did a stethoscope test on the front wheel bearings and had the right replaced and the left was replaced about 9 months ago. They mentioned my tires but they are fairly new and I don't have a shimmy in the steering wheel or an out of balance sensation. Interested in what you guys think. I'm suspecting the rear bearings but I was told they were all checked.
  2. Dec 13, 2012 at 4:58 AM
    Joe D
    Joe D .
    I have nothing of value (much like the rest of my life) to offer except I wouldn't rule out a tire altogether. Oh and, love the thread title! :)
    Have you rotated or repositioned the tire location to see if the symptom changes?
  3. Dec 13, 2012 at 5:25 AM
    cdub105
    Florida
    Ya I've rotated them and same problem. Does anyone know if the recall on the spiral cable could somehow cause this?
  4. Dec 13, 2012 at 5:29 AM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
  5. Dec 13, 2012 at 6:58 AM
    cdub105
    Florida
    Ya but I've had the lift for about 4 years now and just recently had the problem come up. On some other threads they mentioned putting it in 4hi I did that and the sound went away. Now with no warranty should I take it to the dealership or a local shop?
  6. Dec 13, 2012 at 7:29 AM
    Joe D
    Joe D .
    Sorry brother, I'm stumped. I'll keep checking this thread for updates.
  7. Dec 13, 2012 at 7:31 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If the sound / vibration goes away in 4WD , that points to the front diff
  8. Dec 13, 2012 at 7:46 AM
    bzzr2
    bzzr2 Well-Known Member
    mine used to do this, then the stealership replaced the rear diff, and the transmission, and the clutch and tried to say it was my tires, so i said i suggest you prove it cause it did it with stock tires too, they swapped out to wheels from another taco on the lot and same shit, they were sure it wasn't my driveshaft that has play in the slip yoke but they are not the quickest bunch where i went, anyway non of this really fixed the issue. it's there sometimes and sometimes it is not.
    when you let of the gas does it go away? look up vibration nation on this forum, you will find endless information stating the problem is supposed to be normal behavior according to toyota. the odd thing is that it is starting this late, most ppl were reporting this on newer trucks, but this has been reported for years. the one thing i notice is that in colder temps the problem was usually more pronounced and often almost went away once things warmed up well.
  9. Dec 13, 2012 at 8:42 AM
    SitkaSpruceMica
    SitkaSpruceMica Well-Known Member
    TC
    SE Alaska
    2013 SR5 4x4 I4 Auto AccessCab
    ECGS bushing needed. From my reading on this site, anyone with vibration that goes away when shifted to 4HI should upgrade to the ECGS bushing.
    TC
  10. Dec 13, 2012 at 11:34 AM
    cdub105
    Florida
    The CV axle bushings? And ya its still there when I let off the gas and the more I drive it the louder and more consistant it gets. Having another shop look at it tomorrow.
  11. Dec 13, 2012 at 11:58 AM
    DR Da_da
    Alabama
    Negative. Read the thread I linked to above. You'll need to replace the driver's side needle bearing in the front differential with the bushing from East Coast Gear Supply (ECGS). That bushing and the removal tool are found by clicking here.
    While you're at it, replacing the seal is a good idea too.
  12. Dec 13, 2012 at 12:07 PM
    Tayysere
    Tayysere Well-Known Member
    Taylor
    Taylorsville, Utah
    06 ImpulseRed DCSB
  13. Dec 13, 2012 at 4:49 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    I have exactly the same thing going on with my truck, whirr whirr whirr noise, i can kinda feel it in the gas pedal. its at about 30 k in 2nd and 50-60km in 3rd but no other speed. Ive replace both front wheel bearings, no change, Ive rotated my tires, no change[rotating my tires got rid of my steering wheel shake at least]. 2 weeks ago my toyota guy put the front diff bushing in, still there. My cvs are good, carrier bearing has minimul play. I just dont fucking care anymore, I'm hoping now it gets so fuckin bad so I can actually diagnose it. sick of replacing shit hoping it will go away. I dont know how to tell if its a rear wheel bearing, my drums are dry, no sign of axles leaking oil, fuck im just done with it, Im gonna drive it hard til it breaks.
  14. Dec 13, 2012 at 4:58 PM
    cdub105
    Florida
    I hear ya kieth. I'm trying to leave town and dealing with this. Me and my buddies were talking about driving it till something breaks then we would know the real problem. Hopefully tomorrow I can figure something out on the lift. I'm hoping its the needle bearing which a bunch of people said what fixed theirs. Ill keep you guys posted if I find something.
  15. Dec 13, 2012 at 5:51 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    Check you're engine mounts and bearings.
  16. Dec 15, 2012 at 2:08 PM
    kieth
    06 trd
    which bearings?
  17. Dec 15, 2012 at 2:14 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    whats left? rear axle bearing?
  18. Dec 15, 2012 at 2:18 PM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    Definately the muffler bearings. ;)
  19. Dec 15, 2012 at 9:25 PM
    kieth
    06 trd
    i feel kinda stupid but what is a muffler bearing?
  20. Dec 15, 2012 at 9:27 PM
    OZ-T
    Peter North
    British Columbia
    He's fucking with you
