Vibration in gas pedal and cab with a wa wa wa sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdub105, Dec 13, 2012.
  1. Dec 15, 2012 at 9:47 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    when goes over speed bump clank
  2. Dec 16, 2012 at 5:14 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    Kiind of a running joke around here. There's a whole thread on it.
  3. Dec 18, 2012 at 4:51 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    Its funny because I actually searched muffler bearing and was like wait a minute there's threads on this and pictures of the parts, haha. fuckers. So my whaa whar whaa noise is getting worse which is awesome. I'm down to carrier bearing and rear axle bearings. my question is how much play should be in my carrier bearing. I have about 3\8" up and down and side to side, the rubber isn't all dried out . it looks ok. Also would a bad rear bearing be felt up front in the floor and gas pedal? might get my toyota guy to run it on the lift and stethoscope the rear bearings. this is drivin me nuts.
  4. Dec 19, 2012 at 6:52 AM
    Country101
    NW Arkansas
    I believe the carrier bearing does have a lot of play in it. When I did my lift it would move around quite a bit. If it was making the noise I think you would be able to see some kind of problem with it. If you put a lift on, youre driveline angles could be off causing vibration. That's pretty well documented on here, but I dont recall reading about any kind of noise associated with it. You can measure your driveline angles with an iphone app if you dont have an angle gauge and rule that out for .99 or less.
    Dont know about the rear bearings.
  5. May 30, 2013 at 3:36 PM
    3ps14
    3ps14 Well-Known Member
    Orange, CA
    05 trd sport dc
    OME 885s, Black FJ Alloys, TSB AAL, BHLM, Satoshi, Hellas, Black Valence, 6k HIDs
    Sorry to bring up an old thread, but was there any fix for this problem?
  6. Feb 13, 2015 at 11:59 AM
    jsmit357
    jsmit357 Active Member
    Jared
    TN
    TRD SPORT 4X4
    Same problem
  7. Feb 13, 2015 at 12:17 PM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Check your blinker fluid level
  8. Feb 13, 2015 at 5:39 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
