Vibration in the wheel after lift
Discussion in 'Mid West' started by vbeast, Sep 18, 2020.
  1. Sep 18, 2020 at 7:02 PM
    vbeast
    vbeast [OP] Member
    Tacoma
    Vbeast
    Ready lift leveling kit and got 275/70/17 A/T tires and wheels, planning to get Accutune Fox 2.5 coil-over stage 3 shocks front and back
    Hi,
    I have 2020 Tacoma Trd Off Road, i recently lifted my truck and got 275/70/17 A/T. I started noticing vibration while breaking slowly in between 20-30 miles speed. Other thing i noticed was while going in between 40-50 i get other different vibration like (jeezee jeeeze) rubbing feeling in the steering wheel. Note sure what is causing the issue. I tried 4H and dont feel any of those two issues. Any suggestions would be highly appreciated.
  2. Sep 18, 2020 at 7:11 PM
    T00CH
    T00CH Well-Known Member
    Anthony
    Canonsburg, PA
    2020 Tacoma TRD OR
    I noticed a weird sorta rub in my steering wheel after lifting as well...
    As far as the speed related vibration, does it also shake when accelerating between 20-30 and go away above 30? If so, its a tire balance issue more than likely. Also, did you retorque (or torque to begin with) your wheels? Did you have an alignment after your lift?
    Edit: just noticed the part about the speed while accelerating. Still possible wheel balance issue, but see below reply about the carrier bearing
    vbeast[OP] likes this.
  3. Sep 18, 2020 at 7:11 PM
    Shellshock
    Iowa
    Carrier bearing. You need the ecgs bushing
    vbeast[OP] and uploadadventure like this.
  4. Sep 18, 2020 at 7:12 PM
    T00CH
    Anthony
    Canonsburg, PA
    2020 Tacoma TRD OR
    Can you elaborate?
  5. Sep 18, 2020 at 7:18 PM
    Shellshock
    Iowa
  6. Sep 18, 2020 at 7:19 PM
    vbeast
    vbeast [OP] Member
    Tacoma
    Vbeast
    Hi T00CH,
    Yes i did the retorque, balancing, tire rotating. Thank you
    T00CH likes this.
  7. Sep 18, 2020 at 7:19 PM
    vbeast
    vbeast [OP] Member
    Tacoma
    Vbeast
    Hi Shellshock will check on the ECGS bushings,Thank you
  8. Sep 18, 2020 at 7:37 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Needle bearing in front diff.
    What @Shellshock recommends is the fix.
    Shellshock and vbeast[OP] like this.
  9. Sep 18, 2020 at 7:45 PM
    vbeast
    vbeast [OP] Member
    Tacoma
    Vbeast
  10. Sep 18, 2020 at 8:18 PM
    Shellshock
    Iowa
    :cheers:
  11. Sep 18, 2020 at 8:31 PM
    AWBurd
    AWBurd Well-Known Member
    Aaron
    Chaska
    2015Double CabTRD
    What I can’t believe is that Toyota still has NOT remedied this condition. WTF they know what people buy these for! I will also add that my gen 2 2015 made grinding vibes in front after about 3 months post lift. Wheel bearings are garbage for these trucks with heavier tires especially load E MT’s. They go to shit sooooooo fast even good bearings don’t hold up. I just put in 3 rd set this week 110 k miles. I did ECGS bushing after new bearings cleared up most but not all the bushing got it. Huge pain in the ass to install. Actually install easy getting old needle bearings out SUCKS mine was pushed in too far for the special tool no way I used a die grinder and patience to get it out. Good luck.
  12. Sep 18, 2020 at 8:38 PM
    Shellshock
    Iowa
    It’s not an issue on unmodified trucks. I wouldn’t expect them to fix it...
    yoopersteeze likes this.
  13. Sep 19, 2020 at 3:44 AM
    AWBurd
    Aaron
    Chaska
    2015Double CabTRD
    While that is correct it’s just one of those things. What would be really awesome is if you could buy one built, like Ford is doing with the Raptor and new Broncos you can get it the way you want. If you want a plain old pedestrian truck you get the Grandpa F 150 with chrome all over it and crappy street tires or you go balls deep and go Raptor. Same with Bronco you want plain you can get plain or you go all the way and get steel plate protection with lift and 33’s stock! I just feel like Toyota is sleeping at the wheel, and I think it’s going to cost them.
  14. Sep 20, 2020 at 6:15 PM
    Edubreuil
    Edubreuil Back in a Jeep
    Ed
    Cornville, Iowa
    2021 Jeep Gladiator Mojave
    I installed 3 degree axle shims on mine and eliminated similar vibrations.
  15. Sep 30, 2020 at 6:02 PM
    vbeast
    vbeast [OP] Member
    Tacoma
    Vbeast
    Hi all,
    i got the ECGS busing installed on the truck(by toyota dealer). But still i have the same rubbing noise on the steering wheel? any thoughts what to check on next.
  16. Sep 30, 2020 at 6:39 PM
    Shellshock
    Iowa
    Is this the same or something different? When does it happen?
  17. Sep 30, 2020 at 6:46 PM
    vbeast
    vbeast [OP] Member
    Tacoma
    Vbeast
    Yes its the same, while speeding between 40-50 i get the rubbing noise on the steering wheel. I also do have the OEM bushing with me which i can see there is a damage on that, hoping that was the cause but now i am not sure what else to check.
