Vibration issue when shifting into reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhiteStallion07, Sep 13, 2020.
  1. Sep 13, 2020 at 11:57 PM
    WhiteStallion07
    WhiteStallion07 [OP] Member
    Hi there. I am new to TacomaWorld and also a new Tacoma owner. I recently purchased an automatic 07 4wd double cab longbed with 162k miles bone stock. Since I got the truck it has been making this vibrating sensation that almost feels/sounds like gurgling oil? It starts when I shift into reverse and then goes away when I take my foot off of the brake. Once I shift into drive however the vibration seems to continue until I get up to a certain speed. It seems to come and go and is frightening to me because this is a new truck and I put a good chunk of change into the purchase. I just got the oil changed and the tires aligned and the vibration still happens. If anyone knows anything please let me know. Thanks!
  2. Sep 14, 2020 at 5:07 AM
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Does the vibration happen only when you have the front wheels turned as in backing out of a parking spot and then go away as you straighten up or does it also happen if you just back straight and then pull forward?
  3. Sep 14, 2020 at 11:08 AM
    WhiteStallion07
    It happens when the wheels are straight and then goes away when I release the brake but then continues once I shift back into drive. Then it seems to fade away once I speed up
  4. Sep 14, 2020 at 4:19 PM
    doityerself
    The Deep South
    2006 SR5 DCLB 4x4
    Ok. Not what I was thinking then. Sometimes when turning especially, you can have a shudder coming from the rear differential.
    Good luck.
  5. Sep 14, 2020 at 4:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Tranny mount.
  6. Sep 14, 2020 at 7:53 PM
    WhiteStallion07
    The tranny mount needs to be tightened? or what?
