Vibration issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by YOTA HUNTERS, Oct 5, 2023.
  1. Oct 5, 2023 at 11:36 AM
    YOTA HUNTERS
    YOTA HUNTERS [OP] Well-Known Member
    Cranston, Rhode Island
    Hi Toyotaholics,
    I'm having an issue that driving me crazy I'm close to burn the truck down Lmao . My truck is a 2003 double cab 4x4 v6 Automatic So I'm having a bad vibration when I'm in the highway from 50mph and up I never ever had that issue. I already changes the rotors and pads, both front wheel baring, my drive shaft u-joints and center carrier baring, all 4 ball joints tie rods, I just bought 4 new tires and bought some fj wheels thinking maybe my original wheel may he bent. And I'm still having that vibration. Any help is greatly appreciated
    HondaGM likes this.
  2. Oct 5, 2023 at 11:45 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Make sure nobody see's you ....
  3. Oct 5, 2023 at 3:08 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Any history of the rear wheel bearings being replaced? Can you go fast enough for the vibration to go away? Maybe whomever installed the new tires didn't balance them well enough?
  4. Oct 5, 2023 at 3:16 PM
    YOTA HUNTERS
    @Red_03Taco the rear i swapped it because original one was no good. So I bought a parts truck the had the rear end I needed with only 103k miles on it I drove about 50k so far. The vibrations starts at 50 to 65 at 70 starts mellowing out. The tires took to town fair tires they installed the tires balanced them 2 times and did an alignment and still the same thing the vibration you feel more on the floor where the pedals are not much on the steering wheel
  5. Oct 5, 2023 at 3:41 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Put it on jack stands and have someone drive it at 50 and see what shakes. Could be a bent axle.
    wilcam47 likes this.
  6. Oct 5, 2023 at 3:47 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Or bent driveline
  7. Oct 5, 2023 at 3:48 PM
    YOTA HUNTERS
    @wilcam47 when you driveline you talking about the drive shaft?
  8. Oct 5, 2023 at 3:50 PM
    wilcam47
    Will
    Bourbon state
    Yes. Also possible a weight got thrown/knocked off. I think some driveline shops can check it
    MalinoisDad likes this.
  9. Oct 5, 2023 at 3:55 PM
    YOTA HUNTERS
    @wilcam47 I'm going to have to get that check. Stupid question can you see the vibration if I jack it on 4? Probably would be a weight came off because I installed all the u joint on the driveline and carrier baring
  10. Oct 5, 2023 at 3:58 PM
    tacoman2001$
    If something is bent yes. You can feel around to see where the vibration is the strongest.
  11. Oct 5, 2023 at 3:58 PM
    wilcam47
    Will
    Bourbon state
    Prob would see it wobble if its bad enough to see. Id have someone watch for you, while you are in the vehicle. In case it slipped off jacks for some reason
  12. Oct 5, 2023 at 4:20 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Mine was a tire issue,,, had fairly new Wranglers which did the same thing as yours from the get go. I didn't throw any parts at it just figured it was the tires from the way it acted,, 50mph and over to 65 to 70 drive you nuts. Put on new Michelin's , problem solved
  13. Oct 8, 2023 at 7:20 AM
    YOTA HUNTERS
    @pulldo I had KO2 tires for a long time with no issues I bought same tires didn't have an issue but did feel a difference after I took it to take the wheels bearings a slight vibration saw the center carrier baring was bad I changed it and did the u-joint because why not the drive line was already off. Few Weekes later the vibration happened again I don't feel it on the steering wheel. I did notice yesterday while driving 4 hours the transmission shifters shake really really bad
  14. Oct 8, 2023 at 9:55 AM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    I'm thinking of propping up mine on 4 jack stands too, shifting into drive and hitting gas for a while to diagnose a light vibration. If the vibration is still there, what components would that rule out?
    Same with if the vibration is eliminated, what would it rule out?
    Would it also help isolate something to do the same with only the rear tires propped up? I'm imagining a combination of these might reveal something. I don't suppose there's a guide someone has written about this? It seems like a common thing that could be useful.
  15. Oct 8, 2023 at 10:01 AM
    tacoman2001$
    If the vibration is in the air then you know that the tires don't have a hard spot. You can talk them off and rule those out completely. When its in the air you know its not a loose suspension component. If it does it in neutral it's an engine mount. You can also try that going down the road and see if being in neutral makes it better. Being on jacks also rules out front axles as the front wheels shouldn't spin. You can pop out the rear driveshaft and drive in 4wd to see if the rear driveshaft is bent.
  16. Oct 8, 2023 at 10:12 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Road Force Balancing
    Remove Drive Shaft and get it balanced
    Replace rear brake shoes and drums
    I chased everything I could think of.. ended up being the drums.
    ztwatson and ELMO67 like this.
  17. Oct 8, 2023 at 10:15 AM
    YOTA HUNTERS
    @Andy01DblCabTacoma I never thought about the rear drums I did the the fronts with the tundra conversion but never did the back. I'm going to try that out. Because the drive shaft shop that was near me closed and the closes one is almost 2hr away
  18. Oct 8, 2023 at 12:38 PM
    tacohounds92
    tacohounds92 Member
    '99 Tacoma extra cab 4x4
    Please post it on here when/if you get it figured out please. I've been chasing this issue down for a while on my '99. Can't find what's causing it. Good luck!
    ELMO67 likes this.
  19. Nov 17, 2023 at 6:59 PM
    drewmox
    drewmox Well-Known Member
    Andrew
    2003 4x4 3.4L Black DC
    SS3 Fogs, Bilstein 5100s, KC Cyclone 3rd brake, stock AF otherwise.
    I had a vibration that was my fault for losing the alignment on my rear drive shaft. Took it to get it balanced and rebuilt so that's all fixed now. I do still notice a strange power surging feeling on hard acceleration and also a "thud?" or similar feeling to being unbalanced under specific conditions I can't replicate yet. I think it could be the front drive shaft now, or something else driveline, but it's going to drive me mad as well.
  20. Nov 17, 2023 at 9:41 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Front tie rods?
    When taco on Jack stands
    Grab front tires at 9 and 3 o’clock
    Shake…..if play outer tie rods
    this condition would cause high wear on front tires
