Vibration Nation: Complete Thread (60mph vibration)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaneHD, May 22, 2011.
Do you have the vibration?
Poll closed Jun 21, 2011.
  1. Yes
    99 vote(s)
    58.2%
  2. No
    71 vote(s)
    41.8%
  1. May 30, 2013 at 3:29 PM
    #201
    3ps14
    3ps14 Well-Known Member
    Orange, CA
    05 trd sport dc
    OME 885s, Black FJ Alloys, TSB AAL, BHLM, Satoshi, Hellas, Black Valence, 6k HIDs
    So no definite solution to this problem other than buying a new truck?
  2. Jun 1, 2013 at 9:32 AM
    #202
    ShawnMH
    ShawnMH New Member
    Schuylerville, NY
    09 Tacoma
    My issue turned out to be an out of balance driveshaft. Only a faint hint of vibration at 80 - 84 now, barely noticable at all, and acceptable. Dealer tried wheel balancing 1st and charged me for it, came back and demanded a refund, and further diagnosed review of the issue. I have 40,000 + miles on it now, and it is fine.
    Oh, driveshaft was replaced with brand new one, not rebalanced.
  3. Jan 31, 2015 at 4:49 PM
    #203
    J4jim
    J4jim New Member
    Jim
    omaha
    2008 tacoma
    I just bougt a 2008 tacoma reg. cab and have already taken it back to toyota because of vibration and low rumbling noise between 55 and 70. It goes away at 70. They replaced the carrier bearing and the vibration was still there. We are in the middle of a snow storm and I put sandbags in the bed, and guess what? The vibration is gone. Any ideas.
  4. Apr 5, 2015 at 7:05 AM
    #204
    killer4110
    killer4110 New Member
    NJ
    02 PreRunner
    I have an 02 Tacoma, just had the carrier bearing replaced, the first time they replaced it they used an after market one, didn't work so they got one from Toyota and it seemed to work. Than i had to replace the rear u-joint, so here's the problem i'm having.
    Truck rides fine except when i hit 40 mph on the nose, 40-60 mph i get a strong vibration, even if i take my foot off the gas pedal or throw it in neutral while going down the road, once i get over 60 mph the vibration goes away.
    The shop told me to have the trans looked at, but the vibration is there no matter what i do while driving 40-60, i can floor it, OD on/off, throw it in neutral, still there. Any ideas?
  5. Apr 6, 2018 at 6:54 PM
    #205
    jdlmodelt
    jdlmodelt Member
    James
    Silver 2006 4 door SR5
    stock
    Sounds like it changed the angle on your carrier bearings and ujoints when you added weight to the bed.
  6. Apr 7, 2018 at 4:58 AM
    #206
    ccal
    ccal Well-Known Member
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    i had vibration problems at 60 mph also,, I took my wheels to a shop and asked them if they had the hykula adapter, if that's what its called I cant remember, for Toyota rims, they told me yeah they work on high end cars. so any way after 180 bucks the vibes were still there. so I took it to the toyota dealership and rebalanced again. vibes are now gone and truck drives smooth.
  7. Apr 7, 2018 at 7:45 AM
    #207
    jdlmodelt
    jdlmodelt Member
    James
    stock
    mine is in the 55-65 speed. sometimes you can feel it in the seat, floor, slightly in the steering wheel when temperatures are below 50-60 deg F. When it's warmer out, the vib is nearly gone. and also mostly only under load and not while coasting. 2006 Tacoma 4 door short bed 5 speed automatic stock suspension.
  8. Apr 7, 2018 at 8:02 AM
    #208
    jdlmodelt
    jdlmodelt Member
    James
    stock
    Sounds like you threw a tire balance weight.
  9. Jul 17, 2018 at 6:24 PM
    #209
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Reviving old thread- any updates? @Enzo
  10. Jul 24, 2018 at 1:54 AM
    #210
    ALLGNHWII81
    ALLGNHWII81 Member
    Big island Hawaii
    2009 Tacoma DCSB 4x4
    My truck is exactly the same but you can feel a hopping at 31 mph then it goes away and comes back at 45-60 and at this speeds my steering wheel will shake pretty bad, it seems like lots of people have this vibration problem and some are easy fixes. I hope your luck gets better.
  11. Aug 12, 2018 at 8:49 PM
    #211
    Pwhis
    Pwhis Well-Known Member
    Centerville, IA
    2018 DCSB TRDOR
    Anybody find a fix for this vibration?
  12. Aug 13, 2018 at 5:53 AM
    #212
    lynyrd3
    Bill
    East Central Upstate NY
  13. Aug 16, 2018 at 1:13 PM
    #213
    lynyrd3
    Bill
    Slight vibe in the seat between 46-52 mph came along after Dakar install . I will give it some time before I shim anything .
  14. Aug 16, 2018 at 7:21 PM
    #214
    Pwhis
    Centerville, IA
    2018 DCSB TRDOR
    Mine is about 45-60 with deaver aal. Didn’t notice it until 2-3k miles after the install.
  15. Aug 17, 2018 at 5:36 PM
    #215
    Bluesjam
    Bluesjam Well-Known Member
    Paul
    2020 Tacoma SR Magnetic Grey Double Cab 4x4
    Rebalance the driveshaft
  16. Aug 18, 2018 at 4:16 PM
    #216
    BenSkiv
    BenSkiv Well-Known Member
    Ben
    Maine
    2019 Tacoma TRD-off-road DCLB
    So here’s the thing, first off this is my first post, and my first vehicle ever.
    Anyways, I get vibrations around 50-55 mph, not all the time, but occasionally, I can feel it in the seat and the steering wheel. The first time I felt it I thought it was wind, but I now know it isn’t...
  17. Aug 20, 2018 at 12:57 PM
    #217
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    Like most of you i am experiencing a slight vibration. Mine is almost entirely in the steering wheel though. It is also very specific to 55-60 mph. nothing before or after those speeds. Ideas?
    Dye22 likes this.
  18. Aug 20, 2018 at 5:15 PM
    #218
    Dye22
    Dye22 Well-Known Member
    Squamish
    '15 TRDOR ACLB
    JBA UCAs OME 2.5 in lift w/ heavy duty dakars. 33" ko2s tc bed stiffeners firestone airbags w/ ride rites cmc/pinchweld rear flushmount leds amazon ditch lights apex sliders 0 degree w/ kickout Coastal Offroad high clearance front bumper w/ full tubing Coastal Offroad high clearance rear bumper w/ tubing and dual swingout 100 AH LiFePO4 Aux battery blue sea fuse panel for aux battery rear diff mod breather Mountain Hatch tailgate insert Smittybilt x2O 10k winch Anytime Camera Mod Front and Rear GPS locator brick BAMF Hangers w/ custom crossbrace 2lo Mod by up2nogood yakima access cab roof bars thule hyper xl cargo box amazon roof basket ARB 1250 awning WaterPort Meso Dual Color Dome Light Durobump Front Bump stops
    ditto.
  19. Aug 20, 2018 at 6:34 PM
    #219
    CE69
    CE69 Active Member
    Chad
    2015 Blue Ribbon TRD Sport
    I have a 2013 DCSB 2-wheel drive. I like most, I guess, have the same slight floor board and seat vibration between 50-58 mph. I didn't have it or notice it until I had my tranny serviced at 68,000 miles. I don't know what would have caused it, they said the fluid looked very good and they replaced it with Toyota fluid. Of course I can't easily check the fluid level without a dip stick! :mad: I also had the differential fluid changed at the same time, again don't know how this would cause a vibration??
    I also have the famed (axle wrap) vibration on hard acceleration between first and second. Been living with that one, just trying to keep my foot out of the gas!
  20. Aug 21, 2018 at 6:07 AM
    #220
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Seems like most have the issue, but it not many answers. I am wondering if it is something with my wheels and tires. Since it is only the steering wheel that vibrates on mine
