Vibration Nation: Complete Thread (60mph vibration)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaneHD, May 22, 2011.
Do you have the vibration?
Poll closed Jun 21, 2011.
  1. Yes
    99 vote(s)
    58.2%
  2. No
    71 vote(s)
    41.8%
  1. May 23, 2011 at 6:35 PM
    #41
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I read the thread , I guess my question is what are they blaming the issue on if they are resorting to replacing the tranny ?
  2. May 23, 2011 at 6:40 PM
    #42
    ShaneHD
    ShaneHD [OP] Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    Good question. I have YET to get a solid answer on what the issue actually is.
  3. May 23, 2011 at 6:41 PM
    #43
    OZ-T
    Peter North
    British Columbia
    Sounds like they are just throwing parts at it , hoping you will go away .
  4. May 23, 2011 at 6:42 PM
    #44
    ShaneHD
    Fort Worth TX
    I need two new tires anyways, so I am buying a new set. Whats the problem? Of course, I am having them put the tires on first, drive it and see. But after I had said previously, they had already tried this by placing a brand new set from another 2011 Tacoma on mine and the noise was still there.
    If the new tires don't fix it....then the tranny goes in.
  5. May 23, 2011 at 6:43 PM
    #45
    ShaneHD
    Fort Worth TX
    I am not one to go away, especially when I have spent $65k in the last year on my new Tacoma and my wife a new Highlander (2011). I switched from domestic to foreign for reliability. Other than this issue, the truck is solid and have NO problems with out Highlander.
  6. May 23, 2011 at 6:44 PM
    #46
    OZ-T
    Peter North
    British Columbia
    What happens when they replace the tranny and the vibe we all have is still there ?
  7. May 23, 2011 at 6:54 PM
    #47
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    That sounds much better, but why not replace all 4? Didn't you post that they replaced the tires already?
  8. May 23, 2011 at 7:01 PM
    #48
    neoflex
    neoflex Well-Known Member
    At least the dealer is doing something about it. I took mine in and I got the expected, "We didn't feel anything." Yeah well no sh*t! You can't test drive it around the parking lot expecting to feel a vibe I get at 55-60. It's going back this week again as it's driving me nuts and I want to make sure it's on record before I lift it so they can't blame the lift for the vibration should it still be there after.
  9. May 23, 2011 at 7:27 PM
    #49
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I think this pole would be more accurate if you separated auto vs manual. I don't think any manual guys have this issue?
  10. May 23, 2011 at 7:38 PM
    #50
    ShaneHD
    Fort Worth TX
    I've made pretty good friends with my service guy and the service manager. Both are really great guys and understand that I take pride in my vehicles. Just ask to take a ride with the service manager and point out EXACTLY when and how the vibration occurs.
  11. May 23, 2011 at 7:38 PM
    #51
    ShaneHD
    Fort Worth TX
    I believe you are incorrect. I have read anything from 2WD manual and auto to 4x4 manual and auto, lifted and stock....
  12. May 23, 2011 at 7:45 PM
    #52
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Hmmm....can't be transmission or torque converter. Anybody think it might be related to the grinding sensation people feel when they let off the gas at around those speeds?
  13. May 23, 2011 at 8:16 PM
    #53
    ShaneHD
    Fort Worth TX
    Sorry to OZ...double post.....
  14. May 23, 2011 at 8:21 PM
    #54
    OZ-T
    Peter North
    British Columbia
    Why did you quote and post that again ?
  15. May 23, 2011 at 8:23 PM
    #55
    ShaneHD
    Fort Worth TX
    OZ-T, it was an accident......
  16. May 23, 2011 at 8:31 PM
    #56
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Just a thought....
    On top of my other ideas I've presented, I do have one more.
    The cause of the vibration is the engine. This would be a harmonic of the engine plus the drivetrain at the specific engine load and gear. This would explain why the vibration goes away when the throttle is released. This would also would explain why the vibration goes away when the transmission is shifted into 4th.
    I guess the true test of this will be after OP has his transmission replaced.
    Just a FYI, you guys with aggressive off-road tires probably won't feel it. The vibration would probably be masked by the noise and vibration introduced by the tires.
    Anyone the has some technical knowledge about resonant frequencies should understand where I'm getting this idea from.
  17. May 23, 2011 at 8:42 PM
    #57
    ShaneHD
    Fort Worth TX
    Maybe this will all be fixed in the next generation model....
  18. May 23, 2011 at 8:47 PM
    #58
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    If harmonics proves to be the culprit, there will probably nothing that can be done about it.
    The only hope we will have is that.... It's a tacoma, and thats why we bought one. Even with issues(such as half blown up by a IED), they will run forever.
    My only hope is that the vibration doesn't cause premature wear and failure on critical bearings and brushing in the transmission and diff.
  19. May 23, 2011 at 8:55 PM
    #59
    ShaneHD
    Fort Worth TX
    I have 75k miles left in my extended warranty and 11k left in my initial warranty.
  20. May 23, 2011 at 9:09 PM
    #60
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    To be completely honest, if your new transmission doesn't fix it, im not going to be worried about it. It's a jap vehicle. I had a 97 accord that had so many vibrations and noises it was scary. I drove that Damn car all over the country (work). i put 40,000 miles on that car(200,000 when I traded it in). The vibrations didn't get any worse in the time I owned it. I wouldn't think twice about driving that thing across the country.
    The only failure I had was a rear main seal... Related to it not installed properly after a clutch replacement before I owned it.
