Vibration/noise after clutch change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MCRANEY, Mar 2, 2009.
  1. Mar 2, 2009 at 5:27 AM
    MCRANEY
    MCRANEY [OP] WARTHOG
    CRESTVIEW FL
    03 Tacoma 4WD SR5 TRD
    3" Lift 285/75 16R Tires Aries Stainless Steel Grille Guard, KC Lights
    I recently changed the clutch on my 03 tacoma. Thought i did everything by the book. Even resurfaced my flywheel. Now for instance in 2nd gear at low rpm there is a vibration/noise when accelerating for roughly one second. Has any one experienced this problem? It also happens in third and i believe in fourth. I know it has something to do with the clutch because the first time it happened was on the test drive after the clutch change. Any suggestions
  2. Mar 2, 2009 at 8:11 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Did they balance the flywheel?
    Check your u-joints also. Had the same issue on my 98 and it turned out to be the one at my rear axle.
  3. Mar 2, 2009 at 8:27 AM
    MCRANEY
    CRESTVIEW FL
    i toook my flywheel to a machine shop to get resurfaced. i didnt think about it getting balanced. i will go back to the shop and ask if they balanced it. i did take all my drive shafts out when i replaced the clutch. but i just removed the 4 bolts on each end of the drive shaft to remove it. i did not remove the u joints. could that still be the issue? thanks for the reply
  4. Mar 2, 2009 at 8:33 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Dad used to mess with clutches every now and then and I seem to remember talking about drive shafts need to be "in phase"
    He'd mark them and put them back the way they came out cause if they were 180 degrees out they vibrate.
    Anybody else hear that?
  5. Mar 2, 2009 at 8:36 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    My bro in law does that but to be honest, I have never had an issue. I could have put them on right without knowing too.
    It is worth a shot. Check your u-joints. If you don't find a bad one, I would suggest Snipe's idea and maybe disconnect the shaft and rotate it.
