Vibration on Brake Pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OverRated, Mar 25, 2012.
  1. Dec 8, 2014 at 9:13 AM
    #41
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Normally I'd say warped rotors, but not with 4,000 miles unless you've really been abusing the brakes.
  2. Dec 9, 2014 at 3:37 PM
    #42
    Stuart
    Stuart Active Member
    Just got back from the dealership. They said there are no codes and they do not have a '14 with similar brake system to compare to so there was nothing they could do. I asked for the service manager. She had a second mechanic look at it and he was unable to determine if anything was wrong. So the manager wants to have their Tech Serv Rep look at it when he is in town the next couple of weeks. They will also see if they can compare to another '14 if one comes in. This problem just started 5 days ago (4K miles). I never noticed the vibration before. Now it happens every other time I press the pedal and is directly related to the electronic hydraulic booster (not sure the tech name). This does not seem "normal."
  3. Dec 10, 2014 at 5:44 PM
    #43
    GotATacoSuprme
    GotATacoSuprme in Tampa
    Tampa
    '11 TRD OR
    Just had my brakes flushed and there was indeed air in the line. The problem is still there, but I'll have to deal with it.
  4. Dec 10, 2014 at 7:19 PM
    #44
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    I think all 4 runner 2005 and up come with this system. My wife 2006 4 runner has it and it doesn't show any kind of problem. Look for a ABS fuse and take it off to see if ABS is the problem, if it does, look at abs cable sensor in front wheel to see if something is broken or disconected.!
  5. Dec 11, 2014 at 2:06 PM
    #45
    Stuart
    I took my truck back to the dealership I bought it from in Ventura. A field tech specialist took a look at it. They said they were going to replace the entire actuator or accumulator assembly (about $2,000 covered under warranty). Should have it back tomorrow.
  6. Dec 15, 2014 at 9:14 PM
    #46
    Stuart
    Truck is back, new assembly and problem is fixed!
  7. Dec 16, 2014 at 1:19 AM
    #47
    OICU812
    OICU812 Well-Known Member
    Great someone had success with "something". :)
  8. Jan 25, 2015 at 8:43 PM
    #48
    Elev8ed1
    Elev8ed1 Member
    Waimea, Hawaii
    2012 TRD Off Road
    Hey guys, I am wondering if altitude and/or temperature is a causing factor for this vibration. I went up to the summet of Mauna Kea (14,000ft) today, and started to notice the buzz when I started to leave the summet after watching the sunrise. It was a chilly 36 degrees. After reading all of the posts, it seems like a bunch of the same people are describing the same buzz/vibration sound/feel that I am. It never happened before, and I'm wondering if the altitude and cold were the cause. Hopefully Toyota looks deeper into this and issues a recall because it is definitely NOT normal. My truck is. 2012 TRD Off Road. If anyone gets a clear answer on how to fix, please chime in, there are people who would love to know.
  9. Nov 28, 2015 at 6:26 PM
    #49
    2BUKU
    2BUKU Well-Known Member
    Peter
    San Diego, CA
    2014 TRD Off Road Double Cab
    King coilovers, Toyo A/T 33's yadda., yadda...
    Hi guys, started experiencing the same problem on my 2014 dcsb 4x4. Very annoying. I'm about to hit 50k so I don't think it's covered under warranty. Do you guys have any advice? Thanks
  10. Dec 25, 2015 at 7:56 PM
    #50
    ImpulsedComa
    ImpulsedComa Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    Bringing back a very old thread, but this is happening to my 05 dcsb sr5 (actuator vibrating every 2-3 brake presses).
    Not sure why i have this electronic system in my truck (05 DCSB SR5), but never the less, I am having the exact same problem in my truck.
    It started to do it when i got my truck back from the dealer for the frame replacement.
    I posted the question in the forum, but no one seems to have this problem. Here is my thread: https://www.tacomaworld.com/threads/hydraulic-brake-booster-question.323307/
    Anyway its at the dealer now and they are calling toyota on monday because they did another full bleed and the problem is still there.
    Has anyone found out what the culprit to this is so I can relay the info to them? I really need to find an answer while its still at at the dealer.
    thanks
  11. Dec 25, 2015 at 8:02 PM
    #51
    2BUKU
    Peter
    San Diego, CA
    Just a quick update. I parked the truck on a slight downward slope. With the engine turned off I kept pumping the break pedal. Then with the pedal fully depressed I turned on the engine. The break made a large vibration and since then the problem's been gone.
    ImpulsedComa likes this.
  12. Dec 25, 2015 at 8:14 PM
    #52
    ImpulsedComa
    NJ
    thanks, i will do that if they try and send me home from the dealer and tell me its "normal". Id like to find the real answer to this because it was def not there prior to the frame replacement.
  13. Dec 27, 2015 at 6:39 AM
    #53
    ImpulsedComa
    NJ
    Anyone else have any insight on this?
  14. Jan 25, 2016 at 11:30 AM
    #54
    ImpulsedComa
    NJ
    Still having this problem and the dealer will nit own up to it... Any help would be appreciated
  15. Jan 25, 2016 at 11:33 AM
    #55
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Have them measure the rotors to see if they're warped. Unless you've driven like you're in the Indy 500 there's no way they should be warped.
  16. Jan 25, 2016 at 11:37 AM
    #56
    ImpulsedComa
    NJ
    It happens when the truck is in in park. Abs module will cycle every three times i press on the brakes. Not related to rotors, brake pads or anything like that.
  17. Jan 18, 2017 at 9:29 PM
    #57
    KingTaco81
    KingTaco81 The guy, behind the guy, behind the guy
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    Year old thread revival. Any updates on this issue. I'm having the same problem with my truck. Dealer said it 100% normal.
    Pat_Sajak likes this.
  18. Mar 17, 2017 at 3:53 PM
    #58
    Pat_Sajak
    Pat_Sajak Well-Known Member
    North DFW
    08DCSB impulse red
    Same issue with the vibration. Following
  19. Mar 17, 2017 at 4:02 PM
    #59
    ImpulsedComa
    NJ
    Dealer replaced mine free after a month of arguing... My unit was cycling way too much (every time i pressed the pedal) and now it just cycles when the truck turns on and sometimes while driving. The new one is 100% less noisy also. My old one was loud and the vibration could be felt strong in the pedal. The new one is way less noticeable in the pedal and quiet. The dealer cost was like $1500. I really wish I had the regular vacuum brake booster to avoid all these problems and be able to bleed the brakes easily. This brake booster system is confusing and not easy to bleed.
  20. May 10, 2018 at 8:50 PM
    #60
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    Hi! Buzzing for life lol
