Vibration on deceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyYoda1990, Dec 21, 2020.
  1. Dec 21, 2020 at 2:59 PM
    ToyYoda1990
    ToyYoda1990 [OP] Member
    01 tacoma trd
    Stock
    Good day all. I've got a bit of a problem that I'd like to nip before it becomes a disaster and any help from people more experienced than me would be appreciated
    My truck is a 2001 tacoma trd, 3.4, 4wd, with 329k miles, running strong and good.
    I was on a trip in the mountains this past week so a lot of engine braking and I noticed that whenever the truck is decelerating in gear, it vibrates. The vibration seems to be worse at lower speeds, but it happens at any speed and in any gear. If the hill I'm going down is steep enough to cause acceleration or to maintain speed, it doesn't happen, and if I so much as tap the gas pedal, the vibration stops, so the problem is only upon deceleration.
    And it should be noted that I'm not hitting the brakes at all when this is happening, so no rotor problems causing the issue.
    Anyone with any experience or tips would be greatly appreciated
    Thanks in advance
    darktimber likes this.
  2. Dec 21, 2020 at 3:50 PM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    Ujoint
    ColoradoTJ and TnShooter like this.
  3. Dec 21, 2020 at 4:01 PM
    djm228
    djm228 Professional Dumbass
    Dan
    Buffalo, NY
    1998 Tacoma SR5 V6 4x4
  4. Dec 21, 2020 at 4:08 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Ujoint
    Gotta lube them zerks at oil changes
    It's a 4WD man
  5. Dec 21, 2020 at 9:17 PM
    ToyYoda1990
    01 tacoma trd
    Stock
    Thank you all.
    I will be checking that out tomorrow.
    While I'm there, I suppose I should check the center drive shaft support.
    Any tips or links regarding how to do that would be greatly appreciated
  6. Dec 21, 2020 at 9:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If the rubber looks ok, check for play and/or roughness in the bearing.
  7. Dec 22, 2020 at 5:58 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I bought all new ujoints and a carrier bearing. Sent them in to the shop my truck was at. They greased the existing ujoints and replaced only the bearing. Decel vibration is gone.
    Black DOG Lila likes this.
  8. Dec 22, 2020 at 6:05 AM
    Black DOG Lila
    Virginia
    The CB normal play is 1/4 to 3/8"
    1/2" and over is worn out Replace it.
  9. Oct 5, 2022 at 5:37 PM
    brian92s
    brian92s Well-Known Member
    Maryland
    2006 V6 4.0 2WD PreRunner 5’ bed Crew Cab
    Vehicle Modifications:
    My 2006 2WD 4.0 is vibrating when decelerating from 40-30 like clockwork, I think I can notice it at other speeds, but it's pretty noticeable every time from 40-30, is this likely my issue as well?
  10. Oct 6, 2022 at 10:35 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Check your u joints for play. That'll tell ya.
    brian92s[QUOTED] likes this.
  11. Oct 6, 2022 at 1:53 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    yep u joints most likely. Had this happen to me last year on my way back from my Utah trip. About a 11 hour drive from CA to Utah then hit some trails out there for 3 days then drove to AZ flagstaff and then back home to CA. On the way back home from AZ was going up a hill on the 40 and started noticing some vibrations and boom one of the u joints failed. Had to drive back home on the front wheels.
    brian92s likes this.
