vibration on take post lift install
Discussion in 'Suspension' started by hbryanlopez, Sep 25, 2010.
  1. Sep 25, 2010 at 8:03 PM
    hbryanlopez
    hbryanlopez [OP] Well-Known Member
    herby
    mcallen, tx
    black out headlights bilstein 5100s toytec 2" aal procomp 7089 nitto terra grapler 285/70/17
    I just got my bilstein 5100 2.5 at front on toytec 2" aal on my 2011 sr5 prerunner, with shims on the rear. I get some vibration on take off and goes away after 25mph. is this normal, something i should be worried about?
  2. Sep 25, 2010 at 8:07 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Carrier bearing spacer from toytec. That should eliminate the take off shutter.
  3. Sep 25, 2010 at 9:05 PM
    hbryanlopez
    herby
    mcallen, tx
    carrier bearing spacer? is that what its called? i couldn't find it on the toytec website.
  4. Sep 25, 2010 at 9:13 PM
    08pretaco
    az
  5. Sep 25, 2010 at 9:14 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    no, carrier bearing drop from beefed taco. HA :D
  6. Sep 25, 2010 at 9:14 PM
    hbryanlopez
    herby
    mcallen, tx
    cool thanks, where exactly is it installed? I was told by toytec that the shims would take care of vibrations :(
  7. Sep 25, 2010 at 9:16 PM
    08pretaco
    az
    THey are installed inbetween your carrier bearing assembly and the frame. The carrier bearing assembly is the place where your driveshaft joins and is connected to the frame
  8. Sep 25, 2010 at 9:20 PM
    hbryanlopez
    herby
    mcallen, tx
    oh okay, thanks for the info :)
  9. Sep 26, 2010 at 3:19 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    +1
    Haven't purchased one yet. I'll get around to it one of these days but BeefedTaco's drop kit is much higher quality than simple spacers.
  10. Sep 26, 2010 at 3:32 PM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    one piece driveshaft will take care of that shutter...
  11. Sep 27, 2010 at 7:20 PM
    hbryanlopez
    herby
    mcallen, tx
    is this vibration something I should be worriend about and get fixed asap?
