Vibration over 30mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WilsonTheDog, Apr 29, 2013.
  1. Apr 29, 2013 at 8:57 PM
    WilsonTheDog
    WilsonTheDog [OP] Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I've read all the "vibration" and "shudder" related threads so I jacked the truck up tonight and I don't feel excessive play in either front wheels (they move back and forth MAYBE 1/8") and also no growling noise (even spun the wheels while jacked up) so is it safe to assume it's NOT the wheel bearings?
    I'm planning on getting the wheels balanced to rule that out in the next couple days since they're overdue for it anyway (I balance them once a year) and see what happens. It's not a violent vibration but steady and I can definitely feel it. I've changed nothing with the truck since I lifted it over a year ago and this is something that has started in the last couple days. Any further ideas would be welcome.
  2. Apr 29, 2013 at 9:42 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If it just started, perhaps you lost a wheel weight.
  3. Apr 29, 2013 at 9:46 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^That's a good idea. I'll check, thanks for that
  4. Apr 30, 2013 at 6:25 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Had balance done today: still there. Seems SLIGHTLY better but not cured. I did a little "testing" and I only feel it between 30-40 MPH only. Guess I'll crawl underneath and see if everything is tightened up in the driveline.
  5. May 2, 2013 at 1:02 PM
    vargiro
    vargiro Member
    Vinny
    Chesapeake, VA
    06 PreRunner 5
    2006 2x4 club cab, I'm having the same issue with my son's truck! I don't know what he does with it, but I'm sure he abuses it! I had the tires rotated and balanced and I can still feel it. I did a visual check on the shocks, motor mounts and drive shaft and I didn't see anything?
  6. May 2, 2013 at 1:05 PM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    I have a 2008 and it has a very slight one at around 55 mph (but goes away before it hits 60)...but it has gotten a little better since the trans flush and not near as noticeable...
