Vibration problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcliff, Apr 11, 2009.
  1. Apr 11, 2009 at 6:08 PM
    bcliff
    bcliff [OP] Well-Known Member
    Massachusetts
    07 TRD Offroad DCSB
    leaf TSB, added D-Rings, bed mat, weathertechs
    my purchase of an '07 DC short bed is 1 week old and I'm now noticing a vibration problem. When in drive and stopped, I've got a vibration coming right up through the steering wheel. When I put it into neutral, it goes away. I've got the same vibration when accelerating but then when I let up off the gas and "coast", the vibration goes away. I don't notice anything over 2000rpms/35 mph. Much appreciative of any suggestions.
  2. Apr 11, 2009 at 6:21 PM
    BlackTac
    BlackTac New Member
    Washington
    3in ToyTec, steel wheels
    Same problem...sounds like a rear differential problem, just purchased mine as well and from what I hear it can cost up to 4 grand to fix. Suggestion?
  3. Apr 11, 2009 at 9:08 PM
    bcliff
    Massachusetts
    07 TRD Offroad DCSB
    I assume this is covered under the 3yr/36k warrenty? Anybody agree that I have a differential problem or any other suggestions? By the way, I just checked and was happy to discover the previous owner had the leaf TSB done.
  4. Apr 11, 2009 at 9:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    there may be a tsb out for the transmission mount. may wanna look into that first.
  5. Apr 11, 2009 at 10:13 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    is it a noise, or an actual movement of the steering wheel?
  6. Apr 11, 2009 at 10:49 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    If its coming up through the steering wheel and you dont feel it over 35 mph. It might be that you tires need to be re-balanced...... $.02
  7. Apr 11, 2009 at 11:25 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I would say idle speed adjustment or transmission , but if it is going on while you are driving too.... I dunno
  8. Apr 12, 2009 at 5:09 AM
    bcliff
    Massachusetts
    07 TRD Offroad DCSB
    it is more than just noise but I'm hesitant to call it "movement". But it is a distinct movement that you can feel although not see.
    The truck was supposedly aligned and balanced as part of the 160 pt certification but who knows if it was actually done or done correctly. I doubt it is the tire balance because the vibration is present when the truck is in drive, but not in motion. Shift into neutral and it goes away.
  9. Apr 23, 2009 at 5:33 PM
    BlackTac
    BlackTac New Member
    Washington
    My tacomas vibration is different. Mine only vibes at 10-15 mph then goes away (not violent, just enough to notice). I changed the rear differential oil this past weekend and noticed a few metal shavings on the magnetic bolt, but nothing extreme. I flushed and replaced, and the vibe is still there. Also, my drivers rear tire is wearing outside first (uneven wear). Same on the right rear but not quite as bad. Thanks for yalls help! Suggestions and ideas appreciated!
