Vibration problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by falcon174, Jan 14, 2010.
  1. Jan 14, 2010 at 8:48 PM
    falcon174
    falcon174 [OP] Member
    Ontario
    2006 Double cab tacoma
    When I reach between 50 and 60 m.p.h...I am getting a vibration ...any sugestions??? Truck is 2006 double cab short box 50.000 miles everything is stock
  2. Jan 14, 2010 at 8:49 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    tires need air maybe?
  3. Jan 14, 2010 at 8:51 PM
    tacoballs
    tacoballs member
    Jeffrey
    Reche Canyon
    06 4x4 double cab
    tail lights, lift, wheels and tires,navagation, subwoofer,viper security and electric start,bull bar with 2 5in light, billet grill kit, and a 12 in tv
    i have the same problem and same truckk
  4. Jan 14, 2010 at 8:53 PM
    falcon174
    Ontario
    I have the air pressure censors and all seem normal will manualy check though
  5. Jan 14, 2010 at 9:03 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Perhaps the wheels need balancing and or drive shaft.
  6. Jan 14, 2010 at 9:04 PM
    tacoballs
    tacoballs member
    Jeffrey
    Reche Canyon
    06 4x4 double cab
    mine vibrations happen the most when i have dry mud on the inside of my rim so i usually just hose it off and it goes away or a lot of the times its the freewayss
  7. Jan 15, 2010 at 7:27 AM
    Shibby!
    Shibby! Member
    Same thing happens with snow.
  8. Jan 15, 2010 at 7:53 AM
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    balance the tires.
  9. Jan 15, 2010 at 8:04 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Are you still on the factory original tires?
  10. Jan 20, 2010 at 4:34 AM
    falcon174
    Ontario
    K people is was frozen dirt inside my wheel wells thank you all for your insights...
  11. Jan 20, 2010 at 4:47 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Around 60 MPH vibrations is usually tire and wheel balance.
  12. Jan 20, 2010 at 4:49 AM
    Crusher 2
    Crusher 2 Well-Known Member
    N. Virginia
    19 DCSB, SR5, Cavalry Blue, mostly stock
    I just had the TSB for 10-25MPH vibration done on Monday. (Dont' have the number handy at the moment..This is the Tsb for the rear transmission mount) I'm not convinced just yet...but i think my 50-60 vibration under slight load has gone away too! Whoo Hoo! (Oh and the 10-25 went away too)
    I could feel the vibration when under slight load any where between 35 and 70. Usually on gentle up grade or when gravity was pushing you down hill. It felt like it was right under driver's seat/center of vehicle. Went away when you let up on the gas. Frequency of the vibration was definately much higher than tire rotation. Had to be in the driveline somewhere. Get it done before you hit 60K!
  13. Jan 20, 2010 at 8:10 AM
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    I'm taking the truck in for the 15-25mph vibration TSB today. It's apparent in the truck, but I'm still afraid they'll try to blame it on the 3" lift. I have the TSB printed out and ready. I hate the dealership.
  14. Jan 20, 2010 at 4:19 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I had the same problem and just assumed it was time for the wheel to be rebalanced. Had it off to check the brakes and found 3 rocks stuck to the inside with tar/oil. Must have been due to the freeway repaving that's been going on the last 2 years. I'm now calling them redneck tire weights.:D
