Vibration question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brenny627, Oct 26, 2019.
  1. Oct 26, 2019 at 8:07 PM
    Brenny627
    Brenny627 [OP] Well-Known Member
    2019 Barcelona red DCLB
    My truck rode perfect with no issues stock. The dealer in installed a 2.5 in level in front and I installed an aal in the back to give the truck a little take back. The truck still rode great with the stock wheels and tires. I decided to put some methods with 266/75/16 fallen wild peaks. I started having vibrations at various speeds low and high. The wheel does not shake, it is more of a hopping feeling at highway speeds and at very slow speeds (under 5 mph) there is a rotating vibration in the steering wheel. I actually work as a tire guy so I have roadforced them multiple times with no help. The vibe does not go away in 4 high. I am convinced that the falkens are garbage.
  2. Oct 26, 2019 at 8:08 PM
    Bishop84
    Bishop84 Well-Known Member
    If you did a 2.5" lift, you need the axle bushing. Every spacer lift does this.
  3. Oct 26, 2019 at 8:12 PM
    Brenny627
    I am told that if it is the needle bearing it will go away in 4 high, which it does not
  4. Oct 26, 2019 at 8:15 PM
    KGTaco
    KGTaco Well-Known Member
    Southern California
    2019 Tacoma TRD 4x4 Offroad
    King 3.0/Bumps/Deavers/33s
    I don't think bearing
    What PSI do you run?
  5. Oct 26, 2019 at 8:17 PM
    Brenny627
    35, they are not the e rated version
  6. Oct 26, 2019 at 8:20 PM
    KGTaco
    Southern California
    Add some air and see if that helps, 40-45 psi.
    I'm not a fan of Falkens but it shouldn't be too terrible.
    If steering doesn't vibrate/shake, then I'm thinking it's gotta be the lugs and contact with the ground causing an less than preferred feel
    Are you able to go back to stock wheels/tires to test?
  7. Oct 26, 2019 at 8:23 PM
    Brenny627
    I unfortunately no longer have the stock wheels, I’ll try the higher psi and loosen the lugs and torque to spec
    KGTaco[QUOTED] likes this.
  8. Oct 26, 2019 at 8:54 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    You may need a front diff and rear carrier bearing drop kits to get everything back in spec. Don't raise the air pressure, lower it to 30 cold.
    71tattooguy likes this.
  9. Oct 26, 2019 at 9:30 PM
    KGTaco
    Southern California
    His vibration started after the tire/wheel swap, that's why I was taking that variable out for the bearing.
    Usually if I lower the pressure it gets a little more vibration on my tires.
    OP for sure play with the air PSI tho
  10. Oct 26, 2019 at 9:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Lower them to 28-29 psi. That eliminated a lot of vibrations for me after a lift (I'm on C-rated Goodyear Duratracs). Sometimes the stiffer suspension and the tire's stiffer sidewalls cause a resonance issue.
  11. Oct 27, 2019 at 2:10 AM
    VaToy
    Parts Unknown
    He gained some height with the new tires which can cause some vibrations in the driveline.
  12. Oct 27, 2019 at 2:42 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    For a 116SL, you should be at 27 psi.
    I believe Methods are 108mm centerbore; do you have hubcentric ring spacers?
    3JOH22A likes this.
  13. Oct 27, 2019 at 9:14 AM
    Brenny627
    I did install the ome Carrier bearing drop, I was going to try put it back to stock to see if that changes anything, I think having a dclb makes it different then the more common dcsb
  14. Oct 27, 2019 at 10:19 AM
    Brenny627
    I do have the 108 to 106 rings
    splitbolt[QUOTED] likes this.
  15. Oct 27, 2019 at 2:33 PM
    VaToy
    Parts Unknown
    I did it to both my longbed and sons short bed.
