Vibration question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Evdunn, Sep 12, 2020.
  1. Sep 12, 2020 at 10:38 AM
    Evdunn
    Evdunn [OP] Well-Known Member
    Evan
    Edmonton, AB Canada
    2020 Black Tacoma TRD Off Road
    I'm sure this is a really dumb question, I searched around on the forum a fair bit, but vibrations are mentioned A LOT and I couldn't find my answer as plainly as I'm looking for.
    When people speak of vibrations after a lift/level.
    Where/how are you feeling those vibrations?
    Steering wheel, body of the truck, etc?
    Thanks in advance.
    tonered likes this.
  2. Sep 12, 2020 at 11:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The diff needle bearing is an oscillating or intermittent steady vibe in the steering wheel.
    I have both, very slight, with the Stock suspension.
    Skydvrr and Evdunn[QUOTED][OP] like this.
  3. Sep 12, 2020 at 11:51 AM
    Evdunn
    Evan
    Edmonton, AB Canada
    Thanks!
    Installed a 2/1.5 level yesterday, had some gas pedal vibrations afterwards, turned out to just be the alignment.
    No steering wheel vibrations I can feel.
    4x4spiegel and tonered[QUOTED] like this.
  4. Sep 12, 2020 at 12:03 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My tacoma truck is bone stock and i have nothing, nada so far. Don't matter what speed 2 or 4wd. My old gen1 tundra always had some slight vibration...it eventually went away around 80k miles. Oh yeah, imo for some reason toyota pickup trucks made in the last 20 years have been more sensitive to proper tire balancing then older ones.
    tonered[QUOTED] likes this.
  5. Sep 12, 2020 at 12:05 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    The needle bearing was much worse on earlier years. I've seen maybe 2 that failed post 2018.
    Evdunn[OP] likes this.
  6. Sep 12, 2020 at 12:16 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not a tire balance thing. I have heard from folks that have it, worse than me, stock.
    If it goes away when flicked into 4Hi, it's the needle bearing.
    Someday I will swap in the ECGS bushing or do the freehub mod.
    4x4spiegel likes this.
  7. Sep 12, 2020 at 12:17 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff. It is very hit or miss. There are relatively easy fixes though.
    Evdunn[QUOTED][OP] likes this.
  8. Sep 12, 2020 at 12:50 PM
    zoo truck
    None
    I have to admit this truck so far is the smoothest running truck i've had in many years. Definitely not the smoothest ride though. I guess you can't have it all.
  9. Sep 12, 2020 at 1:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oh yeah. Apple to apples, the Taco is a treat.
    I love the ride in mine, but the sway bar is gone. That was the key for me.
  10. Sep 12, 2020 at 1:53 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    that's great let us know if those dreaded vibs return
  11. Sep 12, 2020 at 5:22 PM
    zoo truck
    None
    I have no issue with how the front end reacts....its compliant, and handles corners far flatter than my tundra. Its this dam rear suspension, theres hardly any give. You can feel a sharp jolt every time it hits a sharp edge bump.
  12. Sep 12, 2020 at 5:31 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mine is nice and balanced, loaded or empty. It was just uneven bumps tossing the cab side to side. Almost 30k without it and extremely happy on road and off.
  13. Sep 12, 2020 at 5:40 PM
    RNO_TACO
    RNO_TACO Well-Known Member
    Brent
    Roseville, CA
    2019 Cement Grey Tacoma TRD Off-road 4x4 DCSB
    A.R.E. Topper with victory topper rack, blacked out exterior emblems, star armor side steps, TRD CAI, TRD Pro exhaust, Method MR305 NV 16in Rims, TRD PRO front grill, Meso coin holder, TRD Pro skid plate, Kings 2.5 coilovers with remote resis front and rear, OME HD Dakar’s, ECGS, LT285/75R16 KM3s, Dirt king UCAs, Meso gas cap holder, Meso blacked out interior kit, TRD start/stop red button, AVS low profile window guards, AVS low profile hood protector, Full LED upgrades inside and outside, decked bed storage system. And I’m sure there’s more I’m missing lol
    I’m curious on where you are getting this data? The needle bearings haven’t changed in years and many many many members post 2018 have had needle bearing issues once lifted and required to go aftermarket EGCS. Now complete failures where it grenades your diff is a different story. I believe this is what you are referring to correct? In that case, I completely agree :cheers:
    tonered likes this.
  14. Sep 12, 2020 at 5:47 PM
    OMGitsme
    Sold
    Just reading this board.
  15. Sep 12, 2020 at 5:49 PM
    RNO_TACO
    Brent
    Roseville, CA
    Hmm, I see it much differently I suppose. :crazy: numerous threads on needle bearing failures. Anyway, not going to hijack the OPs thread. Just was inquiring is all. Take care.
  16. Sep 12, 2020 at 6:10 PM
    4x4spiegel
    uneven bumper , please expound
  17. Sep 12, 2020 at 6:17 PM
    Evdunn
    Evan
    Edmonton, AB Canada
    A diff drop kit came with the level, but I couldn't get the spacer in. The skid plate mount has a lip on it that wouldn't let me pull it down far enough to slide the spacer in.
    Its a bigger spacer then I've seen in most kits. About 1.5"
    Do people have to remove that mount piece and trim it? Or should I try a 1" spacer?
    I watched some videos and no one had any problems so I was scratching my head.
  18. Sep 12, 2020 at 6:17 PM
    Evdunn
    Evan
    Edmonton, AB Canada
    Are the vibes generally only felt in the steering wheel?
  19. Sep 13, 2020 at 5:57 AM
    zoo truck
    None
    Well, from what i'm reading these long bed taco's have similar if not the same issues i've mentioned with mine. Guess its normal. I've already spoke with the dealers service manager about it when at my 1st visit, plus the odo issue...all they did was double check the tire pressure, and say your suspension will take awhile to settle in...truck is still very new. At least they straightened out why my odo was reading fast...its dead on now.
  20. Sep 13, 2020 at 7:47 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    My bad. Uneven bumps.
    4x4spiegel[QUOTED] likes this.
