Vibration / Rumble When Braking - Between 30 mph and 10 mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco Luvr, Apr 11, 2018.
  1. Apr 11, 2018 at 12:45 PM
    Taco Luvr
    Taco Luvr [OP] Well-Known Member
    2016 TRD 4X4 OR
    King Ext, TC UCA, 1.5 AAL, VTX Rogue SL, BFG KO2 285/75R16
    There is a TSB (0171-16) that addresses this exact symptom while decelerating that calls for shimming and replacing leaf springs to correct driveline angles, but after visiting my local service department and discussing the TSB with the manager, I learned I was dealing with something completely different.
    I wanted to post something to help anyone with the same vibrations I was having as to avoid chasing it for too long.
    I have a 2016 TRD OR, lifted with 2.5 King OEM mid-travels and an AAL in the rear. I had the “rumble strip” vibration thing going on pretty bad. You could feel it in every seat and pretty bad in the brake pedal and driver floor.
    Took a ride with a tech at Toyota and he said it felt like warped drums to him. I thought "Oh, great. This guy doesn't have a clue."
    They kept my truck overnight and ordered new drums to install under warranty < 36K.
    I thought for sure they were just treating a symptom and that the problem would persist. Because I have modified my truck to the extent that I have, I thought for sure this would be an issue with "driveline angles" as mentioned in the TSB. I went along with them anyway. Why fight it when they were willing to do work under warranty?
    They asked me who I had work on my brakes and they seemed very surprised when I told them no one had touched my brakes.
    They said the drums were way over-tightened and that it must have been done at the factory. They owned it.
    The work order described considerable warping in the drums as well as the rotors. They turned the rotors as well. My truck only has 32,000 miles on it.
    So far, so good. The truck stops with no vibrations.
    Will it prove to be a fix and the vibrations not return? We’ll have to see, but for now it’s all good.
    If you are experiencing this, have them inspect your brakes!
  2. May 5, 2018 at 12:23 PM
    NateBolo21
    NateBolo21 Well-Known Member
    Nate
    Dirty Jersey
    Taco
    Tacoma Bed Mat Tacoma All-Weather floor mats Tacoma Tri-Fold Bed Cover Salex OCD Console Organizer & Tray Nox-Lux matte black overlay badges Nox-Lux matte black tailgate inserts Excalibur Remote Start ME-SO Customs Coin holder/Lid ME-SO Customs Map Lights ME-SO Customs Ultimate Dome Light ME-SO Customs Extended Fuse Cover ME-SO Customs Ultimate Turn Signals ME-SO GassHole Kicker tweets, 6 x 9's & 6 x 3/4's JL Audio AMP / Stealthbox MBRP Cat-back Exhaust TRD PRO Gear Shift Knob Mobtown Off-Road Sliders TRD CAI PRO Grill Cali-Raised Ditch Lights Cali-Raised Bumper LED Light Cali-Raised OEM Style Switch Panel CH4x4 OEM Ditch Light Push Switch CH4x4 OEM Bumper Light Bar Push Switch TRD PRO Rigid Fogs TRD PRO Bilstein Suspension Baja Kits UCAS SCS RAY 10's Matte Bronze Sexy [Machined Lip] / Spline Lugs 265/70/17 Nitto Ridge Grapplers
    @Taco Luvr I think I am experiencing the same issue. Almost feels like a grinding/rumbling in the brake pedal when stopping, as if brakes are having trouble engaging? Thanks for your time. Nate
  3. May 9, 2018 at 6:47 AM
    Taco Luvr
    2016 TRD 4X4 OR
    I didn't have so much the grinding issue, but definitely a rumble.
  4. May 9, 2018 at 9:30 AM
    NateBolo21
    Nate
    Dirty Jersey
    Taco
    Yes TL, grinding was the wrong way to describe it.... more of a rumbling as well! Replacing the rotors as we speak.... hopefully problem solved! Thanks for your reply:thumbsup: Nate
  5. Jun 5, 2018 at 3:05 PM
    Marconis
    Marconis Well-Known Member
    New York
    2017 SR5 DCSB 4X4
    Been noticing rumble in the 30-10 mph range for a bit now during deceleration, was going to bring it up at my 10K service (I'm at 6K right now). However, I now noticed a rumbling when braking as well anywhere in the range of 10-30 mph. It isn't consistent, wondering if I am just feeling the rumble strictly under decerlation. Also having brake pedal issues, which I've posted about. Will see if I can make it to my 10K without anything changing/becoming unbearable.
  6. Jun 6, 2018 at 11:28 AM
    Gozer the Gozerian
    Gozer the Gozerian Member
    Portland, OR
    2010 V6 Access Cab 4x4 Off-Road (Mag Grey)
    I just put a lift on with new tires and get fairly extreme rumble strip vibrations in the 10-25 mph range, especially when decelerating. Switching to 4Hi had no effect, so I don't think it's the needle bearing. Was thinking driveline angle, especially since I have a 4" lift. I'm going to start with the lift installer.
