Vibration/shudder off acceleration.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shreddinlemur, Jan 31, 2023.
  1. Jan 31, 2023 at 6:36 AM
    Shreddinlemur
    Shreddinlemur [OP] New Member
    2012 Tacoma access cab trd 4x4
    Leveling kit spacers in front (1”or 2”)
    Hello to all, I’ve done tons and tons of research on this and have even taken it to the dealership. It is a very minor vibration/shudder but is something I want to fix. The slower you go off take off the less you feel it. Also not as bad when truck hasn’t warmed up all the way. I’ve changed diff fluid, trans fluid, new u joint, greased u joints and it’s still there! Dealership told me everything checks out fine and to just drive it. I do have the “clunk” feeling at times when coming to a quick stop. Not sure if that could have something to do with take off. I’m running out of ideas to remedy this so any help would be greatly appreciated! Thanks
  2. Jan 31, 2023 at 8:38 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Many people have this issue. Mine has had a little take off giggle feeling since new.
    Shreddinlemur[OP] likes this.
  3. Jan 31, 2023 at 9:40 AM
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    The "clunk" might indicate one or more worn motor mounts/transmission mount(s).
  4. Jan 31, 2023 at 9:42 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW...
  5. Jan 31, 2023 at 4:04 PM
    Pacificclam
    Pacificclam Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    Your carrier bearing may be wearing out... have you pushed on your drive shaft to see if there is a lot of movement?
  6. Feb 1, 2023 at 9:11 AM
    Shreddinlemur
    I’ve inspected it in the past and it’s not rotted or anything. I will double check the play when i get a chance. Thanks
  7. Feb 1, 2023 at 11:48 AM
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
