Vibration through steering wheel at 40mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boatman00, Nov 1, 2020.
  1. Nov 1, 2020 at 4:14 AM
    boatman00
    boatman00 [OP] Member
    Kentucky
    14 TRD Sport DCSB 4x4, MGM
    I have been struggling for the past 4 months with a vibration, Can be felt through the steering wheel starting at 40mph, Tires have been balanced and rebalanced several times, Carrier bearing and u-joints replaced, really feels like a driveline vibration, after about 50 mph it gets much less noticeable, This vehicle is bone stock with no lift, Also removed the rear driveshaft and road tested with no difference felt, Installed the ECGS bushing about 50K miles ago, At wits end with this problem?
    Thanks for any suggestions
  2. Nov 1, 2020 at 1:05 PM
    c212
    c212 Well-Known Member
    Couple of SWAGs here...
    Dragging brakes, with slight rotor warp from heat over 4+ months due to constant dragging?
    Some crap stuck between the rim and hub so the rim isn't seated fully flat against the hub?
    Try swapping rims front -> back and back -> front?
    You could also have a ply/tread separation. Sometimes you can spot those by jacking the vehicle up and looking straight at the tread while you spin that wheel.
  3. Nov 1, 2020 at 1:08 PM
    Taco'09
    Taco'09 Well-Known Member
    Try the easy stuff first. Since you are feeling it in the steering swap the front tires to the rear
    and bring the rear to the front. Make sure the wheels are torqued properly using a torque wrench and the appropriate spec. (81 ft. lb.) and sequence. Make sure all tires are inflated to spec. Any change noted during test drive?
  4. Nov 1, 2020 at 2:40 PM
    boatman00
    Kentucky
    Tires have been moved front to rear, No noticeable difference, I for sure feel this is driveline related as it is speed related and not rpm related, Vibration is there at 40mph regardless of engine rpm, Have not checked rotors, Doesn't really feel like a tire vibration as much as a rough bearing vibration?
    Thanks Guys!
  5. Nov 1, 2020 at 4:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    So a road test WITHOUT the rear driveshaft resulted in - No Change?
    How are the front wheel bearings?
  6. Nov 1, 2020 at 5:13 PM
    boatman00
    Kentucky
    They have no play that i can feel, Also when vibration is present when going around curves cant tell any difference in vibration, I suspected front wheel bearings also.
    Thanks
  7. Nov 1, 2020 at 5:14 PM
    c212
    What about CV joints? Boots look ok? Weeping any grease at the ends? How many miles on them? Sometimes they'll "feel rough" when you're holding the steering wheel.
  8. Nov 1, 2020 at 5:17 PM
    boatman00
    Kentucky
    Both boots look great, No weep anywhere, They are both OE on the vehicle with 114K miles
  9. Nov 1, 2020 at 5:28 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    So did you have any work done at all before this mystery appeared 4 months ago ?
  10. Nov 1, 2020 at 5:32 PM
    boatman00
    Kentucky
    Absolutely nothing was done, Vibration could possibly have been getting progressively worse and wasnt noticed before?
    Any reliable way of checking cv joints?
  11. Nov 1, 2020 at 5:33 PM
    c212
    Phew... this is beyond me, then. However, I saw an interesting case of a Jeep Grand Cherokee exhibiting some of the same symptoms as yours. Plus the driver was complaining of a faint roar along with slight vibration. The Tech had it up on a lift with the tranny in low (auto) & engine running. Long story short, it turned out to be a bone-dry transfer case. Definitely one for the Weird Shit file cabinet, but I thought I'd mention it. I guess I'm out of ideas. Sorry....
    TnShooter likes this.
  12. Nov 1, 2020 at 5:35 PM
    boatman00
    Kentucky
    No problem, Have checked all fluids and everything is ok.
    Thanks
  13. Nov 1, 2020 at 5:53 PM
    Taco'09
    Chris(NJ) and Jimmyh like this.
  14. Nov 2, 2020 at 3:10 AM
    boatman00
    Kentucky
    Lots of info here for sure! will take some digesting.
    Thanks
  15. Nov 2, 2020 at 6:54 AM
    jhinderliter
    jhinderliter Well-Known Member
    West central il
    2009 Double Cab TRD Off Road
    Balance the tires
  16. Nov 2, 2020 at 8:00 AM
    boatman00
    Kentucky
    Thank you, I have had them balanced several times including road force balancing, could be the tires but at this point don’t know what else to try?
