vibration when accelerating from a stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nighthawk87, Mar 20, 2011.
  1. Mar 20, 2011 at 2:46 PM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    My truck vibrates when accelerating from a stop. It used to always to it a little but seems to have gotten worse.
    the only things I've done is a 2.5" King Shocks lift in the front with the toytec TSB add-a-leafs in the back. tires are BFG A/T KO's 265/70/17.
    Any ideas????
  2. Mar 20, 2011 at 2:49 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    At what speeds to the vibes occur?
    And vibes after lifting are quite common. When you change the angle of the driveline, things are gonna shake a bit...
  3. Mar 20, 2011 at 2:51 PM
    nighthawk87
    vibes when accelerating from a stop.....and when slowing down at about 20mph
  4. Mar 20, 2011 at 2:52 PM
    jandrews
    Stop to what? Stop to 10 mph or stop to 70? Makes a difference.
  5. Mar 20, 2011 at 3:03 PM
    nighthawk87
    stop...as in not moving anymore
  6. Mar 20, 2011 at 3:04 PM
    jandrews
    Fuck it.
    nemesis17592 likes this.
  7. Mar 20, 2011 at 3:09 PM
    phatdrew
    phatdrew Well-Known Member
    drew
    dover, de
    2" lift, 17" pro comp wheels, 285x70x17 micky t's, billet grill
    what speed does the vib stop at when accelerating?
  8. Mar 20, 2011 at 3:13 PM
    nighthawk87
    OK, I see much clearer :)
    It stops at probably 3-5 mph very brief....if I accelerate really slow it doesn't do it.
  9. Mar 20, 2011 at 3:19 PM
    kickers15l5
    kickers15l5 Member
    Kile
    Rogers, AR
    Mine does it at about 15-25 stock.
  10. Mar 21, 2011 at 12:51 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    May want to check your U-joints. I had a u-joint go bad & felt what you are feeling.
  11. Mar 21, 2011 at 3:02 AM
    muddog321
    muddog321 Member
    fl
    09 tacoma doublecab 4wd trd w/e locker
    Lots of posts on this - Carrier bearing angle and weak rubber internal support in it. Raise it and the angle changes - even the rear spring TSB effects it - makes it worse. Mostly at take off and when slowing and shifts into 1st when I feel it.
  12. Mar 21, 2011 at 5:32 AM
    nighthawk87
    Muddog, how do I fix it then?
    Genexer, what do I look for on the u joints?
  13. Mar 21, 2011 at 5:58 AM
    crawldad
    crawldad Well-Known Member
    2016 TRD OR 4X4 Quicksand
  14. Mar 21, 2011 at 6:08 AM
    nighthawk87
    Crawldad, I tried using washers already with no effect. It probably dropped about .5"-.75". Any other ideas?
    How much does toytecs kit drop it?
    What is the point if it anyways, why does the Tacoma have a two-piece!? My ram didn't and it was longer.
  15. Mar 21, 2011 at 6:51 AM
    KevLot17
    KevLot17 Well-Known Member
    Kevin
    Pennsylvania
    '10 Blacked Out TRD Sport
    Debadged, Toytec Ultimate Lift, Banks Monster Exhaust, AFE Pro Dry filter, Black Grillecraft grille, Flat Black background headlights, Red Blinkers and markers with alternating turn signal mod, Krypton Bulbs 6000K Headlights and Fogs, Fog Light anytime Mod, LED interior lights with map light mod, AVS Black Taillight Covers, Tinted Windows, WeatherTech Digital floor liners.
    Please refrain from comparing your 'mid-sized awesomemobile' to your 'full-size....:facepalm:Dodge'
    Brian007Taco likes this.
  16. Mar 21, 2011 at 7:41 AM
    nighthawk87
    Hey the ram was a good truck in many ways the Tacoma isn't. I Appriciate both actually. Overall the Tacoma is better but the ram didn't have vibration issues :p
  17. Mar 21, 2011 at 8:10 AM
    JasonJump
    JasonJump Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    Hey bud I had this problem and it was because I had recently done a rear diff oil change, have you messed with your diff and maybe used synthetic? If not and I were a betting man I would say U bolts, tighten those bitches to 90lbs torque at least. A lot of guys on here have found that to stop that stutter after doing a lift etc.
  18. Mar 22, 2011 at 7:13 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    You could try a rear axle shim. This will rotate the axle on the perches. The pinion will rotate up putting it more in line with the drive shaft.
  19. Mar 22, 2011 at 7:20 AM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    Mine does as well...There is a TSB for this. Replacing the rear transmission mount if the vibes are between 15-13 on 2007-2008 Im going to have it done at the next oil change.
    T-SB-0132-08 JUL 08 Drivetrain - Driveline Vibration Between 15 - 25 MPH
  20. Mar 23, 2011 at 4:57 AM
    ecoterragaia
    ecoterragaia Well-Known Member
    Mid-Atlantic
    '06 RC, 4X4, 5 speed
    Very interested in this . . . we're not supposed to use synthetic gear oil, even if it meets specs? Does this apply to LSD or open differentials, or both?
