Vibration when accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by robow, Jan 19, 2012.
  1. Jan 19, 2012 at 3:17 PM
    robow
    robow [OP] New Member
    Bill
    Acton, CA
    06 Pre Runner
    My truck gets a very noticable vibration whenever I accelerate, in any gear. Plus there are some noises, clanking, dinging? also. I can't describe the noises very accuratly but the vibration is very noticable and is worse the harder the acceleration. What could be the cause?
  2. Apr 3, 2012 at 10:37 AM
    Gleason05
    Gleason05 Well-Known Member
    Codie
    Goochland, Virginia
    2003 Tacoma SR5 TRD
    Tinted Windows Black Grille Black Bumpers Painted Stock Wheels Pioneer Stereo
    my truck has just started gettin the same vibrations during acceleration, still trying to figure out the cause
  3. Apr 3, 2012 at 10:45 AM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    possible wheel bearing... get it checked to see if it needs replacing
  4. Apr 3, 2012 at 3:27 PM
    lonecountryboy
    lonecountryboy Well-Known Member
  5. Sep 1, 2013 at 9:09 PM
    brandon0551
    brandon0551 New Member
    biloxi , mississippi
    2010 tacoma TRD sport
    6 inch pro comp lift , 20in XD SPY ON 35IN NITTO TRAIL GRAPPLERS , WESTIN ULTIMATE BULLBAR
    I have a fix to everyones problem , ive found out how to fix the shutter when starting off and the vibration when driving . if anyone needs to know how you fix these aggravating problems . the fix cost about $160 bucks. buy 3 new ujoints ( i used moog brand ) , drop the center bearing down about an 1 1/2 and put shims in , bolt everything back up and your problem is fixed . the problem is the drive shaft angle . why toyota let this problem go as long as they are , its crazy , and they still dont have a fix for it . the ujoints are in a bind because of the angle . on these trucks , even though the ujoints look good while theyre bolted to the truck , you will be able to tell once you take them off . the ujoints take care of the vibration while driving and dropping the center bearing takes care of the shutter starting off . if you have any questions , just pm me .
    Franck144 likes this.
