Vibration when barely on gas pedal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Twday87, Nov 3, 2015.
  1. Nov 3, 2015 at 4:47 PM
    Twday87
    Twday87 [OP] Member
    Thomas
    2004 Tacoma CrewCab TRD
    I've got a slight vibration seems like somewhere in the driveline when I'm on the highway and I barely touch the gas pedal. It goes away if I let it coast and goes away if I push harder on the accelerator. What's the problem here?
    2004 double cab
    Trd stock Suspension
  2. Nov 5, 2015 at 7:07 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    u-joint maybe but more then likely its a bad carrier bearing or maybe both.
    to test, jack rear end off ground, support with jack stands and wheel chocks, then get under there and wiggle the u-joints and test the carrier bearing for movement, its ok to have about 1/8" of wiggle in the carrier bearing but I would be concerned if it has any more then that. naturally you want no play in any of the ball joints
  3. Nov 5, 2015 at 10:17 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Mine was doing the same. I figured it was the u-joint. Just feel like doing it. It got much worse so it was time and got around to it. Just drove it the past couple hours. No vibration at all.
  4. Nov 6, 2015 at 6:27 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    U joint or cv joint (usually the inner).
  5. Nov 6, 2015 at 10:18 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    U-joint
  6. Nov 12, 2015 at 2:58 AM
    Twday87
    Twday87 [OP] Member
    Thomas
    What's the cost of doing that? Hard to to myself?
