Vibration when braking!
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotaforlife08, Jan 25, 2014.
  1. Jan 25, 2014 at 12:51 PM
    yotaforlife08
    yotaforlife08 [OP] Well-Known Member
    Justin
    Wells,ME
    2015 DCSB TRD OR
    TRD PRO wheels 265/70/17 falken wildpeak at3w HS 2 inch coils 1.5 rear leafs. bilstein 5100's all the way around. husky liners,coverking seat covers. tinted 20%
    Hey guys picked up. 2001 dc Tacoma 4x4 this is my 3rd Tacoma. Love them. Well this one had a vibration when I bought it (picked it up cheap) so anyway went ahead and did bilstein 5100s new roots pads and calipers. And after all that I still have a vibration when breaking it's worse the faster I'm going as I try to stop. I haven't got my Alignment yet only been one day because if it's balljoints I'll need another. But anyway guys I'm stumped what could this be! Please help a taco lover out.
  2. Jan 25, 2014 at 1:26 PM
    scyota03
    scyota03 Well-Known Member
    sumter,southcarolina
    03 trd prerunner
    3 inch coil spiring spacer, front bull bar
    did u get new rotors when u replaced the pads?
  3. Jan 25, 2014 at 1:29 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    x2
  4. Jan 25, 2014 at 1:36 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    id say check all your balljoints and get alignment first because it could be that(also make sure your wheels are balanced). but maybe it could be some of your steering bushings? considering you replaced the rotors pads and calipers there is not too many other things it could be. does it look like its been in front end collisions before?
  5. Jan 25, 2014 at 1:45 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Check if wheels are tightened properly, Check tires for balancing (weights), check for bad rotors, check rear drum balance (they have weights on them I believe and can fall off over time), check drive shaft balance (also have weights), also if rear drums are adjusted too much it can cause shake on braking I'm outta ideas after that
  6. Jan 25, 2014 at 1:52 PM
    addicted7369
    addicted7369 She Thinks My Tacoma is Sexy
    Al
    Middlesex County, N.J.
    06 Tacoma Sport DCSB 4X4
    Toytek 3" ultimate lift Billstein 1500 coilovers, and Light Racing UCA's with AAL in the rear, Mickey Thompson classic lock III rims with color matched powder coated color rings,with 285/75R16 General Grabber AT2 tires led tail lights , T-Rex Billet grill, HID reverse lights, FLYZEYE V2W led lights, throttle body spacer, and K&N air filter, Kenwood head unit, Rockford Fosgate punch 6 1/2" speakers, 6x9 Rockford Fosgate punch speakers,1 inch Rockford Fosgate prime tweeters, 5%tint all around, CBI rock sliders, Cobra 19 CB with 3' firestik antenna, 6 1/2" lightforce 170's behind grill, redline elite hood struts, retro fit HID projector head light with halos and demon eyes, weather tech floor liners, led interior lights, truxzedo low profile bed cover, rear diff relocation mod, anytime fog light mod.
    sounds like to me you have a warped rotor
  7. Jan 25, 2014 at 2:23 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Go back and RE-check everything you replaced....sometimes WE miss a simple bolt or torque something just enough to create NEW problems...
    It does sound like one of the rotors is causing this BUT if they are NEW warranties should apply...
    If all else fails there is a shop up near you trusted by your NH neighbors;
    archiesoffroad in Wells... great people and a "local sponsor" over at
    http://forums.exploringnh.com/forum.php
    Good luck..
  8. Jan 25, 2014 at 2:50 PM
    addicted7369
    Al
    I think he said he didn't replace the rotors but very well could be
  9. Jan 25, 2014 at 2:51 PM
    yotaforlife08
    Justin
    Wells,ME
    2015 DCSB TRD OR
    Archie's my cousin. Thanks for the help guys. I rechecked everything. And I don't think it can be a rotor because after replacing the rotors it started doing it right away. It's gotta be ball joints or wheels out of balance
  10. Jan 25, 2014 at 2:52 PM
    addicted7369
    Al
    oh ok you replaced the rotors ok well good luck I you are able to find the problem and correct it
