vibration when idling
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmack, Nov 22, 2015.
  1. Nov 22, 2015 at 4:49 PM
    jmack
    jmack [OP] Member
    Does anyone know why my 2001 2.4 automatic vibrates when idling in park?
  2. Nov 22, 2015 at 4:55 PM
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Is there anything done to it?
    Do you have an exhaust?
    Loss of power?
    Any codes?
  3. Nov 22, 2015 at 4:58 PM
    jmack
    jmack [OP] Member
    don't have any of the above.
  4. Nov 22, 2015 at 5:02 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    How bad is the vibration?
  5. Nov 22, 2015 at 5:08 PM
    jmack
    jmack [OP] Member
    it shakes the antenna like crazy and I ment to say it does it in drive not in park
  6. Nov 22, 2015 at 5:12 PM
    jmack
    jmack [OP] Member
    its almost like its idling to low
  7. Nov 22, 2015 at 5:38 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    torque converter maybe? possibly not unlocking and allowing enough slip which puts more load on the engine pulling it down at idle causeing it to vibrate...any other symptoms? fast jerky shifts? having to really hold the brake at a stop?
    had a 97 ford escort that did this and it was torque converter...idled fine in nutral and park and drove fine with no codes...just idle weird and sometimes ( very seldom only in winter-very cold) stalled in the first few miles if it wasnt warmed up before i drove it...
  8. Nov 22, 2015 at 5:47 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    all 4 cylinders idle rough in gear like its missing or something, hundreds of guys here have spent small fortunes replacing everything they can think of and nothing ever fixes it.
    its normal so just learn to get used to it and don't waste time or money on something you cant fix.
  9. Nov 22, 2015 at 8:18 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Check all your exhaust hangers. Maybe where the pipe goes into the muffler. Sometimes they rust out, break and doesn't even look like it.
  10. Nov 22, 2015 at 8:25 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    When you're in gear the truck will idle lower because there's a load on the engine. 4 bangers do idle rough. My 2TR is much rougher than the 2J in my IS300. It's all about balance.
    Learn to love your truck for all its shakes and rattles and you'll live a much happier life.
  11. Nov 22, 2015 at 9:18 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Ive been chasing my idle shake for almost 3 years without luck. Mine idles at about 550rpm and no matter what I do or which part I replace it still does it
  12. Nov 24, 2015 at 4:42 PM
    jmack
    jmack [OP] Member
    Thanks for every ones input
    TacoMitch93 likes this.
  13. Nov 24, 2015 at 6:13 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    mounts. my toyota tech buddy says it's the tranny mount. check them. have someone rev the engine while you're looking at the mounts or the engine itself. it will probably tilt a bit without the body. the body is supposed to tilt with the engine.
    ever see an old 22r or 22re motor starting up in a toyota pickup? they shake like crazy. bad mounts is all.
  14. Nov 24, 2015 at 6:21 PM
    CodeSeven
    Serge.
    Coachella Valley
    here's a motor starting up and revving with bad mounts. you can see it shifting a bit.
    here's a 22r motor starting up with good mounts. can barely see any movement.
  15. Nov 24, 2015 at 6:26 PM
    CodeSeven
    Serge.
    Coachella Valley
    vibrations when idling in drive happen because the tranny is slowing down the engine and it runs unbalanced under idling RPMs. your mounts are supposed to soften that imbalance and prevent any roughness. old, disconnected, or hardened mounts cant do their job properly.
    this is the case like 85% of the time
    DyegoPC23 and Xbeaus like this.
