Vibration when shifting
Discussion in '4 Cylinder' started by dgjones, Jul 28, 2012.
  1. Jul 28, 2012 at 7:23 AM
    dgjones
    dgjones [OP] Well-Known Member
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Hello Everyone,
    Here are the symptoms and Its worrying me that this may cost a ton of money.
    09 Taco 4cyl 2 wheel drive - standard pickup. Automatic 45,000 miles
    When shfting from 3rd to 4th and 4th to overdrive, the truck is vibrating very badly. I assume there is an issue with the transmission. It also does it when downshifting as well. How bad is it? don't sugarcoat it.
    It has been a phenomenal truck so far and this is my only issue. I just started happening.
  2. Jul 28, 2012 at 8:43 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) In order to help you we may need a little more information or clarification of your vibration. Does your taco vibrate in first or second gear or in reverse?
    You could have a broken motor mount or a transmission mount broken, you need to examine and test them to see if they are the trouble.
    You may want to examine your drive shaft and look at the universals. You may have a two piece drive shaft and the middle support may be the problem. I would look first, before you start to blame the transmission. It could be a internal failure, but you would be having more transmission problems if it was the fault. Good Luck.
  3. Jul 29, 2012 at 6:42 AM
    dgjones
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Hmmm good suggestions. It vibrates bad when shift from 3rd to fourth. But the vibration stays unless I punch the gas or let off the throttle. Something may be out of balance.
  4. Jul 29, 2012 at 4:25 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Have you ever greased the driveshaft slip-yoke? It might be hanging up. There aren't any zerks so if you try it you'll have to remove the driveshaft, unclamp the rubber boot, and separate the driveshaft into two pieces. It took me about 1.5 hours from start to finish. Make sure you clean the everything really well, and make sure that you have replacement clamps.
  5. Aug 2, 2012 at 11:56 AM
    Fozzie
    Fozzie Member
    Fozzie
    Could be a torque converter problem, but more likely something simple, like u-joints.
  6. Aug 2, 2012 at 12:14 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    sounds like when i had to replace a u-joint
  7. Aug 2, 2012 at 12:24 PM
    greensunset
    greensunset Member
    Maria
    Oahu
    06 XRunner
    Its manual or automatic transmission?
    If manual, the problem is balance, or tire align. You will notice when reach certain speed.
    I dont know if this is the correct name, but is something related to balance.
  8. Aug 2, 2012 at 2:18 PM
    Midnight Drifter
    Midnight Drifter Well-Known Member
    Anthony
    Monroe Twp, NJ
    2TR W/T
    Flowmaster dual exhaust
    Funny, I didn't know my A340E had 5 gears. :der:
  9. Aug 7, 2012 at 2:14 PM
    BamaToy1997
    Bill
    Navarre, FL
    OP mentioned in his opening post that he has an automatic. Tire balance issues typically show up around the 55 MPH range.
